> just installed dump pipe
post Mar 1, 2007 - 10:17 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I just got my stock dump pipe off my 3sgte and am installing an xs power one. The old convertor assembly weighs a bunch! I couldn't believe it! Not only am I removing a major restrictive cat. off a turbo car, I weighed the two pipes and Im loosing 8 pounds! That doesnt include all the brackets Im not going to use. Money well spent. later
-brian
post Mar 1, 2007 - 10:27 PM
2 things.... before you bolt on your downpipe... move the wg flapper open/close to make sure it doesn't hit on the edge of the new dp. if it does, you need to grind the flange down on the downpipe.
2nd... make sure you use the support bracket on the bottom. if you dont, your downpipe will crack.
post Mar 1, 2007 - 10:31 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
post Mar 2, 2007 - 11:56 AM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(lagos @ Mar 2, 2007 - 3:27 AM) [snapback]531969[/snapback]
Def need to get this done. I've personally seen two crack - badly.
Lo-Fi Version Time is now: January 10th, 2025 - 4:57 AM
