> Spacers, 7th gen GTS rims
post Mar 3, 2007 - 11:26 PM
snapshotgt
Joined Oct 12, '05
From Texas
This is a thread for those how have had first hand experience with spacing out GTS rims. Wondering what you're using SIZE wise, and what you would recommend SIZE wise to make a flush, but functional setup with 50/55 tires (sidewall).
H&R spacers of course…
My current thought would be 5mm spacers, but would like to hear from people that have had first hand experience.
Please post pictures if possible.
Thanks-
post Mar 3, 2007 - 11:33 PM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(snapshotgt @ Mar 3, 2007 - 11:26 PM) [snapback]532599[/snapback]
Thanks-
I made my own 1/4" spacer.. using 225/55/16's .. 7th gen rims of course.. 1/4" is a cunt hair over 6mm. A thicker spacer would be nicer though.. I'd say more like 1/2" .. however, 1/4" is nice.. plus you don't need to do anything with the studs.
87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
post Mar 4, 2007 - 1:24 AM
snapshotgt
Joined Oct 12, '05
From Texas
No matter what size i go with, i will be buying H&R spacers --> don't want to screw around with something so crucial.
GTS rims are 39mm offset correct?
post Mar 4, 2007 - 3:00 AM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(snapshotgt @ Mar 4, 2007 - 1:24 AM) [snapback]532630[/snapback]
What do you mean something so crucial? You do realize that a 1/4" spacer does not require anything to be done with the lugs right? The only thing a 1/4" spacer will be is a round piece of machined steel or aluminum and 5 holes drilled in it... I don't care what brand you go with.. it's not like I'm selling them.. Just want ya to know that a spacer that thin is nothing special at all.
post Mar 4, 2007 - 2:13 PM
snapshotgt
Joined Oct 12, '05
From Texas
H&R spacers are hubcentric, precision engineered, and have unrivaled fit.
post Mar 4, 2007 - 4:48 PM
there was a guy on here with a white celica that had 7th gen rims with spacers that looked really good. i think he was using a 15 or 25m spacer. try searching the members profiles.
i wouldnt bother with a 5m. it wont make much of a difference, and like punisher said, with a sparer that small, it really doesn't matter much what you use. even pepboys stocks 5m spacers. but if you go with a 15 or 25m, thats when you really want a quality spacer.
This post has been edited by lagos: Mar 4, 2007 - 4:48 PM
post Mar 4, 2007 - 11:01 PM
CelicaST202
Joined Apr 2, '06
From Socal
you would have to re-torque spacers every 100-200 miles or so.
post Mar 5, 2007 - 12:29 AM
I've driven ~2,000 or more miles with 16mm spaced in the rear , 5mm spaced in the front.....i've never retorque....and its the same
post Mar 5, 2007 - 1:20 AM
6gc_driven
Joined Apr 16, '05
From Orlando, FL
QUOTE(playr158 @ Mar 5, 2007 - 12:29 AM) [snapback]532908[/snapback]
X 2
..ive had spacers since december 06'..driven 3,000+ since, and have never had to re-torque my spacers
post Mar 5, 2007 - 2:05 AM
CelicaST202
Joined Apr 2, '06
From Socal
i guess you guys dont take it to the track
post Mar 5, 2007 - 2:12 AM
ok back on topic
what size spacers are ideal for 7th gen 16" GTS wheels ?
post Mar 5, 2007 - 2:21 AM
the wheels are 6.5 wide and have a 39mm offset with 205/50/16 tires.
post Mar 5, 2007 - 2:38 AM
celicaST
Joined Jun 23, '05
QUOTE(Batman722 @ Mar 5, 2007 - 12:21 AM) [snapback]532933[/snapback]
http://www.6gc.net/forums/index.php?showtopic=32534
according to that,
(6.5/2)*25.4-(39-x)=74, would need a 30mm spacer for standard ride
(6.5/2)*25.4-(39-x)=63, would need a 20mm spacer for lowered ride
post Mar 5, 2007 - 2:45 AM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(snapshotgt @ Mar 4, 2007 - 2:13 PM) [snapback]532740[/snapback]
Did you get that little bit from their website? Good luck finding a hubcentric 5mm spacer.
The "ideal" spacer really depends on what look you are going for.. and also tire size. a 5mm spacer will clear 225/55/16 in the rear.. nothing larger.
The front doesn't need a spacer for that size.
post Mar 7, 2007 - 10:48 AM
QUOTE(celicaST @ Mar 5, 2007 - 2:38 AM) [snapback]532939[/snapback]
according to that,
thanks
yeah I saw that. So 15mm spacers should be more than acceptable, just not out as far as the 20mm. OK.
post Mar 9, 2007 - 2:56 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Okay.. question... not to hijack or anything, but my 17X7 rims have an offset of +42. I want to at least get the rear more flush, so which size spacer should I look into?
**** Photobucket
post Mar 9, 2007 - 4:17 PM
celicaST
Joined Jun 23, '05
QUOTE(95CelicaST @ Mar 9, 2007 - 12:56 PM) [snapback]534753[/snapback]
(7/2)*25.4-(42-x)=63, x=16.1, so i would get a 15mm spacer
post Mar 9, 2007 - 5:26 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
Do we even actually NEED the spacers? Or did you want them just for the flush look?
I run 16" 7th gen gts rims with the standard tire (205/50/16?).
Thanks-
post Mar 9, 2007 - 6:01 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
spacers are just for the flush look.
I have 7th gen rims with 205/50/R16's
And...
I have Ichiban 15mm spacers up front and 20mm spacers in the back, they are installed and look a little sunk with my stock 14" wheels. But it should look almost exactly flush on my lowered car. I dont know yet though because, as i said, im on 14" winter stealies right now tongue.gif
This post has been edited by Tech9ine: Mar 9, 2007 - 6:03 PM
Lo-Fi Version Time is now: January 11th, 2025 - 5:02 PM
