> mr2 trans. conversion update, Not so good. Need some help..please
post Mar 4, 2007 - 2:04 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Ok so I just got my mr2 turbo transmission in my car and took it for a spin today. There is a loud grumbling noise/vibration on acceleration and decel. only. kindasad.gif Im feeling like its drive axles, but I had them apart and lubricated them and they looked fine. On the driveres side I did use the mr2 inner space and boot assembly. But I used the mr2 inner shaft that goes into the transmission. I used a full spacer (OEM axle spacer) on the passenger side. I didnt use one on the driver side. When I have the front jacked up and spin the wheels the side Im turning spins ok. The other side doesnt move unless I go to the other side and move it by hand. Everthing seems in place and tight. With the car on the ground the axles look straight. I used the st205 rear and drivers motor mounts. Any ideas what may be wrong?????? Thanks
-toyotacrazy
This post has been edited by toyotacrazy: Mar 4, 2007 - 2:08 PM
post Mar 4, 2007 - 6:42 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Ok Im relisting this on the mr2 short axle solution. I think my spacer is too wide.
post Mar 4, 2007 - 8:54 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Are you sure all your lug nuts are tight? Seems like a silly question, but that will cause exactly what you're describing.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 5, 2007 - 12:06 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Dr_Tweak @ Mar 4, 2007 - 8:54 PM) [snapback]532857[/snapback]
-Doc
Yes. The lugs are torqued. The axle on the pass. side seems to be binding. Im pretty sure thats what Im feeling/hearing. It just kinda feels like a drive axle issue.
post Mar 5, 2007 - 9:56 AM
Of those OEM "spacers" you mean the metal pieces with the grooves in the center in between the inner & outter axles correct?
If you got 2 full of those in between and managed to put the wheel back on I'd be amazed. I couldnt do it. I was about 1'' to long of an axle for me to put the hub in the axle. I had to CNC machine it down to about 1/2 the size.
I also have a noise of some sort; I cant be sure but I think its my carrier bearing.
This post has been edited by Supersprynt: Mar 5, 2007 - 9:57 AM
post Mar 5, 2007 - 7:40 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Yes I got it in with 2 OEM spacers. And drove the car. I unbolted the lower ball joint with the 2 nuts and 1 bolt. I made 3 spacers all different sizes so I can hopefully get it back on the road tonight. Any suggestions what size I need? Thanks for the interest!
post Mar 5, 2007 - 7:41 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
did you use the angel clips on the axles. without em your axles could vibrate
post Mar 5, 2007 - 7:42 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(rjbibeau @ Mar 5, 2007 - 7:41 PM) [snapback]533219[/snapback]
Do you mean the c-clips that come with the oem axles?
Lo-Fi Version Time is now: January 10th, 2025 - 9:50 PM
