help, car shaking |
help, car shaking |
Mar 6, 2007 - 8:02 PM |
Enthusiast Joined Feb 16, '07 From Sheboygan Currently Offline Reputation: 0 (0%) |
my uncle just bought a celica recently, now the car shakes or vibrate a lot. this happens mostly when we are driving above the speed limit of 15 and give it gas. the only issues that the car has right now is dead shocks. what im thinking of is the bearings.... but im not sure and want to discuss it on here. i just want to see if anyone of you guys here have this problem and may help me figure what is wrong. thank you -john
Mar 6, 2007 - 8:06 PM |
Enthusiast Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
Well first thing is replace the shocks. But it also could be a motor mount.
Mar 6, 2007 - 8:43 PM |
Enthusiast Joined Mar 14, '06 From Mary Land Currently Offline Reputation: 0 (0%) |
alignment?
Mar 6, 2007 - 8:48 PM |
Enthusiast Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
i think thats ur bearings, happened to me before. If you like to see if it's ur bearing, jack up your car and see if there's any play in the wheel. Sometime its not all that accurate, i took my whole spindle out and actually was able to wiggle my hub.
This post has been edited by My2Celi: Mar 6, 2007 - 8:51 PM -------------------- <--- I miss :'' (
Mar 6, 2007 - 9:16 PM |
QUOTE(Toyoca @ Mar 7, 2007 - 1:43 AM) [snapback]533680[/snapback] alignment? no he just got his alignment done, it's accurate QUOTE(My2Celi @ Mar 7, 2007 - 1:48 AM) [snapback]533683[/snapback] i think thats ur bearings, happened to me before. If you like to see if it's ur bearing, jack up your car and see if there's any play in the wheel. Sometime its not all that accurate, i took my whole spindle out and actually was able to wiggle my hub. i could try that to my uncle's car then, but would the dead shocks have any effect on it? |
Mar 6, 2007 - 11:04 PM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
It could be your drive shaft. I just had this problem, it's been ongoing for the past 6moths but got worse this past week. Got it looked at during the summer and it was wearing.
As I accelerated above 30mph i got this sudden vibration. Replaced my drive shaft and problem solved. Signs to look for: torn rubber boot covering the knuckle. It was vibrating because the boot was torn and the grease basically "dried" out. -Christee- |
Mar 7, 2007 - 4:18 PM |
QUOTE(CelicaQT @ Mar 7, 2007 - 4:04 AM) [snapback]533739[/snapback] It could be your drive shaft. I just had this problem, it's been ongoing for the past 6moths but got worse this past week. Got it looked at during the summer and it was wearing. As I accelerated above 30mph i got this sudden vibration. Replaced my drive shaft and problem solved. Signs to look for: torn rubber boot covering the knuckle. It was vibrating because the boot was torn and the grease basically "dried" out. -Christee- thank you, i'll be sure to take a look at that. |
Mar 7, 2007 - 5:52 PM |
dead shocks wont have any effect on them. hope you find your problem. let us know what was the actual problem for future reference.
Mar 8, 2007 - 6:27 PM |
Just because he did his alignment, it does not mean something is off in his tires like a slight warp of defect or even tire balancing.
Mar 8, 2007 - 8:29 PM |
it was the timing belt, and the tires weren't balance out, right now i have a clicking noise when i shift.. im thinking it's the clutch because it happens only after i shift or clutch. but im not sure yet, the clutch doesn't seem to have wear out yet.
Lo-Fi Version | Time is now: January 11th, 2025 - 11:07 PM |
