Question, Tires Rubbing |
Mar 8, 2007 - 9:46 AM |
Enthusiast Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
So, I've been noticing when i make sharp turns going slow (like into a parking spot) i hear a little rubbing. This sounds like plastic rubbing on my tires, and I cant really see any irregular wear, but the noise is annoying. To fix this, do i need wheel spacers so the wheels arnt catching the plastic on these sharp turns, or what needs to be done? Thanks guys... any help is appreciated
Mar 8, 2007 - 9:58 AM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
mine did that b/c my wheel well cover was messed up. you can just take that off or just fix it so that it is moved away from the tires. i had to tiewrap the well cover to a part of the chassis to keep it from moving.
Mar 8, 2007 - 10:24 AM |
ah ok this makes sense... thanks for your fast help... im thinking your right because i've had a couple incidents (like hitting a raccoon) where the plastic in the wheel well might have been moved
Mar 8, 2007 - 1:28 PM |
yeah, wheni got mine it was like that on the right side, which was incidently in an accident but repaired by the owner i got it rom. except the part i got.
Mar 8, 2007 - 1:33 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
QUOTE(tim86 @ Mar 8, 2007 - 3:24 PM) [snapback]534267[/snapback] ah ok this makes sense... thanks for your fast help... im thinking your right because i've had a couple incidents (like hitting a raccoon) where the plastic in the wheel well might have been moved been there done that too! those lil buggers must love the sexy celi or something haha -------------------- |
Lo-Fi Version | Time is now: January 12th, 2025 - 6:56 AM |
