upgrade audio?, i know nothing about audio |
Sep 30, 2007 - 10:42 PM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
Buy a reputable 4 channel amp. 75rms x 4 for example. Cheap ebay amps do not produce the power they rate, do not last and some of them will make your system sound like crap.
Buy a good 6.5" component set for the fronts. Use 12mm MDF to make up spacers.Doesnt take long and all you need is a jigsaw and drill. Buy a SVC(single voice coil) 4ohm subwoofer. Now, wire 2 channels for the front speakers and bridge the 2 other channels for the subwoofer. If you find that it is not enough, simple. Buy a monoblock for the subwoofer and use the 4 channel solely for the fronts(bridge 1/2 and 3/4) IF you want rears, simple too. Connect the stock speakers to the headunit directly using its internal amp. There is no need to upgrade the rears. 6x9s are only for people who do not have the space for subs and want some thump. They are painful to listen to and there is no point in having them if you have a subwoofer. |
Oct 1, 2007 - 12:12 AM |
Enthusiast Joined Jul 29, '07 Currently Offline Reputation: 2 (100%) |
Yz
This post has been edited by Komail: Sep 29, 2015 - 11:52 PM |
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:56 PM |
