3 Pages V  < 1 2 3 >
> HTR FWD BUILD UP, FWD Beast
post Mar 9, 2007 - 4:21 PM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
QUOTE(lagos @ Mar 9, 2007 - 3:40 PM) [snapback]534766[/snapback]
so whats the story behind your rwd car? why are you building a fwd one if you already have a 9sec celica?
The FWD car is the RWD car now, it's the same car. Im building the green one for the street "won't be driven every day" but will be able to run in the NHRA sport FWD class, that's why im building it. The story with the RWD is i'm in the process of building a 2007 RWD Scion TC and the RWD celica is almost sold.
IPB ImageIPB Image
This post has been edited by HARDTARGET: Mar 9, 2007 - 4:28 PM
2007 Scion TC 1/4 Mile ET 7.06 @ 195 3/4 chassis! Motor SOLD: 3SGTE
1980 Toyota Corolla 1/4 Mile ET 7.92 @ 175 Full Street Legal! Motor: 3SGTE
1983 Toyota Corolla 1/4 Mile ET 7.42 @ 187 10.5 Tire Street Legal: 3SGTE
1998 Toyota Celica RWD 1/4 Mile ET 7.82 @ 175 SOLD! Motor: 3SGTE
1994 Toyota Celica FWD IN THE WORKS
2000 Toyota Celica GTS 1/4 Mile ET 13.50 @ 109 DAILY DRIVER
https://www.facebook.com/htrracing
WWW.HARDTARGETRACING.COM
post Mar 9, 2007 - 10:21 PM
InfamousChappy
Joined Sep 30, '06
From Knox Vegas, Tennessee
How are you gonna hook up 8 or 900 FWD horsepower and be able to drive it on the street? Just curious.
post Mar 9, 2007 - 10:22 PM
jdg371
Joined Jun 14, '05
800BHP in a 5SGTE is crazy lol. That turbo will be size of the engine haha.
I wonder if they would permit you to run a 503E.. It's been fitted and ran in a MKII MR2.. =] Just a thought.
post Mar 9, 2007 - 10:36 PM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
QUOTE(InfamousChappy @ Mar 9, 2007 - 11:21 PM) [snapback]534872[/snapback]
I'm not planning on street racing, it will be a waste of time. anything over 450hp on a FWD car on the street is a waste, it will never hook up. The car will be able to drive as far has the meth fuel takes it.
post Mar 9, 2007 - 10:43 PM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
QUOTE(jdg371 @ Mar 9, 2007 - 11:22 PM) [snapback]534874[/snapback]
do i need to say more.IPB Image
post Mar 9, 2007 - 10:47 PM
just a quick question...why a 5s block ?
post Mar 9, 2007 - 10:50 PM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
QUOTE(Batman722 @ Mar 9, 2007 - 11:47 PM) [snapback]534882[/snapback]
stronger than any 3s gen 1 or 2, haven't done a 3rd gen yet.
post Mar 10, 2007 - 12:55 AM
jgreening
Joined Jan 17, '04
From Illinois
Just out of curiosity, can you stay below 5500 RPMs and never reach positive manifold pressure? On a WOT run, will it fall out of boost when shifting? How high will you rev it on a WOT run?
post Mar 10, 2007 - 2:10 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
post Mar 11, 2007 - 6:52 AM
Alan
Joined Jan 23, '05
From Malta
Yeah like what is that Turbo? and how much does the motor need to rev to spool up, Do You use antilag or NOS for it to spool
post Mar 11, 2007 - 4:09 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(HARDTARGET @ Mar 9, 2007 - 10:50 PM) [snapback]534885[/snapback]
How do you figure a 5s block is stronger than a 3s block. Ive seen dozens of 5s-fe throw a rod for no reason, on a well maintained car, being driven normally, with plenty of oil. Just curious. Not trying to criticize you.
post Mar 11, 2007 - 6:37 PM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
QUOTE(toyotacrazy @ Mar 11, 2007 - 4:09 PM) [snapback]535292[/snapback]
the oiling system on factory 5s sucks your right, when i take a 3s and a 5s block and put over 40 lb of boost and run it down the 1/4 mile and crack the 3s block almost every time and "NEVER CRACK" the 5s block, that's why the 5s block is stronger for me and other reason.
post Mar 11, 2007 - 6:58 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(HARDTARGET @ Mar 11, 2007 - 6:37 PM) [snapback]535319[/snapback]
Where does it crack?
post Mar 11, 2007 - 6:59 PM
doesn't the 5sfe have thicker walls then a 3sgte newayz?
5s blocks are often used for stoker motors as well
post Mar 11, 2007 - 7:02 PM
that would be because the 5s, and the 7a for that matter are known for having weak rod bolts.throwing a rod thru the block says nothing about the blocks intergrity.
a little research on mr2oc will net quite a few reasons people use the 5s block, besides the .2 liters that you gain with it.
QUOTE(toyotacrazy @ Mar 11, 2007 - 6:58 PM) [snapback]535326[/snapback]
they tend to crack between the bores.
post Mar 11, 2007 - 7:06 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
between 2 and 3 because of the internal coolant passage.
post Mar 11, 2007 - 8:08 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
This thread is very interesting. I believe the rod studs pull out of the rod. From what Ive seen anyways.
post Mar 12, 2007 - 8:43 AM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
QUOTE(toyotacrazy @ Mar 11, 2007 - 7:58 PM) [snapback]535326[/snapback]
they tend to pull the head stud closest to the water pump right off and so do the older 5s blocks also.
post Mar 13, 2007 - 9:35 AM
use L19 head studs?
post Jan 23, 2009 - 4:30 PM
HARDTARGET
Joined Feb 20, '07
From W.P.B, FL
Well guys it's been a while, but it's time to get this car done, finally got some spare time to work on the car, I'll get some updated pics but not much diff from before just got the intake manifold almost done.
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: November 24th, 2024 - 10:39 AM
