those with a 3s-swap (2nd gens) |
Mar 9, 2007 - 12:22 PM |
Enthusiast Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
Those with the 2ND GEN swap, did you keep your MAF set-up or did you convert it?
Just curiouse... -------------------- CLOSED on 25 acres! -shop coming soon.... |
Mar 9, 2007 - 12:37 PM |
I think a majority of us still have the AFM.
Mar 9, 2007 - 12:42 PM |
i converted to speed/density with the aem.
gm 3bar MAP, and gm AIT sensors used. -------------------- |
Mar 15, 2007 - 11:38 AM |
(Sorry it's been awhile since I replied to this post)
x_itchy_b_x, why did you decide to swap? And for those still useing the MAF, how large is the inside diameter of the maf unit? -------------------- CLOSED on 25 acres! -shop coming soon.... |
Mar 15, 2007 - 1:47 PM |
because of an aftermarket turbo that needs larger injectors than the stock ecu can't* run so i had an option to eliminate the AFM with the AEM so i did. more accurate readings than a swinging door on a spring/potentiometer.
This post has been edited by x_itchy_b_x: Mar 15, 2007 - 1:59 PM -------------------- |
Lo-Fi Version | Time is now: January 12th, 2025 - 5:04 PM |
