> auto to manual, st185 parts
post Mar 9, 2007 - 7:21 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
ok, so when converting from auto to manual in the st trim and also doing the 3sgte swap is it possible to use the master and slave cylinders, clutch pedal, manual brake pedal and all that stuff from the st185 or do i have to use st204 or the at100 parts. it would be nice to be able to use the st185 parts cuz i got a front clip and **** but let me know. the shifter plate is revrsed in right hand drive cars right so our 5th is there 1st, if im right on that is it possible to just rotate the linkage points or get a new plate. anyways any help would be great
post Mar 13, 2007 - 11:39 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
the shift points are not reversed, 1st and 5th are in the same place for RHD and LHD
most likely you can use the ST185 slave cylinder since is not directly connected to the pedal like the master cylinder is... even so the master cylinders should be pretty similar, if anything it might just be a difference in mounting position. I do not know if the pedals fit but my assumption is that since they bolt to a different chassis they might be slightly off and it would be easier to just get the pedals from a 205, but since you have the parts why not give it a shot first and see
I <3 Dustin---07/16/06
Lo-Fi Version Time is now: January 13th, 2025 - 12:07 PM
