my timing belt broke tonight, the date is set, guys help me out |
Apr 23, 2007 - 9:36 AM |
doing it in Newport, no air
both camshafts are fine Jeremy -------------------- |
Apr 23, 2007 - 9:34 PM |
Ah, all good.
I'll try to make it down there, but I work 'til 4PM on Sat. If I can make it, is there anything special tool wise you guys might need? I was kidding about the camshafts. Sorry -------------------- |
Apr 29, 2007 - 12:00 AM |
You know, it didn't register that it was this weekend until just now....
How far along are you? I'll try to call Manny tomorrow. I have something going on. -------------------- |
Apr 29, 2007 - 10:01 AM |
we didn't do anything on Saturday, but today (sunday) is the day it should be going down.
Apr 29, 2007 - 7:47 PM |
oh it went down! i'm sure that paper towel we left in one of the cylinders will be fine.
Apr 29, 2007 - 9:08 PM |
QUOTE(x_itchy_b_x @ Apr 29, 2007 - 8:47 PM) [snapback]552263[/snapback] oh it went down! i'm sure that paper towel we left in one of the cylinders will be fine. or the little plastic thingy i threw down in there...i cant remember if i grabbed it before we put the head back on or not...lmao D, just make sure steff is nowhere near that engine when you try and start it,...i'd hate to see her get burned... good times. get her all buttoned up, i wanna see that beast back on the road! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 29, 2007 - 9:42 PM |
Enthusiast Joined Jul 18, '06 From plymouth, MA USA Currently Offline Reputation: 0 (0%) |
my belt was done once back before i had the car when it had 60k on it, the cars got 125k now so im going to get it done soon do you guys know what id be looking at for price to have it done i know all shops vairy but is there a ballpark someone can give me thanks
Apr 29, 2007 - 10:26 PM |
yup it happened. The head gasket, timing belt, and water pump went in really without any snags...except a broken sensor out of the water neck. It's the one closest to the head, I think it's the water temp sensor for the EFI.
I'm gonna get everything buttoned back up in the next few days after work, should take a couple of hours to get it 100%, I just need the time and daylight. Thanks to Manny & Jenn, ze Horniak, and Steff <3 -------------------- |
Apr 29, 2007 - 10:31 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
good stuff Dustin. I happy you're almost up and running again !
-------------------- I will return one day. |
Apr 29, 2007 - 10:33 PM |
Thanks Jeff.
I forgot to mention the pass side axle that didn't hold up to the strain of no mounts o well, now both the boots are torn on that side it was worth it -------------------- |
May 1, 2007 - 12:25 AM |
May 1, 2007 - 12:41 AM |
you got ever last mile out of that belt.. haha
May 1, 2007 - 4:39 PM |
Enthusiast Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
maybe i didnt catch it, but how many miles did you have on that belt?
May 1, 2007 - 4:45 PM |
QUOTE(DSToyo @ May 1, 2007 - 5:39 PM) [snapback]553002[/snapback] maybe i didnt catch it, but how many miles did you have on that belt? 146,441 IIRC from writing it on his sticker for him -------------------- |
May 1, 2007 - 6:06 PM |
ribbed for her pleasure
May 3, 2007 - 10:10 PM |
Enthusiast Joined Oct 12, '06 From USA Currently Offline Reputation: 0 (0%) |
i know for sure it's not an interference motor. One way to know for sure whether or not it's an interference motor is while you have the timing belt off, you should be able to spin the crank with no resistance, meaning it's not hitting any valves. so you should be safe, now if your replacing the head gasket, my tip to you is to BUY EVERYTHING, because while you have the head off, it's a good idea to replace the valve seals, clean up the valves by lapping them, and clean the whole head because after you are all done, that motor will last another 200k miles.
May 5, 2007 - 1:03 AM |
update
since we got the new HG, timing belt, and water pump all in on Sunday I have had to time to put everything back together until today. I did do a little bit each night (in the dark ) but I had half of the day today to finish all the loose ends. So now I have everything back together and I replaced the broken temp sensor with a spare and everything is 100% now. No CELs, no clanks, no leaks (yet), no problems. During the downtime I had I did manage to do a few upgrades like a new HU, new speakers, 7th gen wheel, adjustable rear sway bar end links, new front bushings, replaced a bad wheel stud, painted the cooliing panel, J Speed bar and valve cover black, fixed a squeeling front wheel (thanks Manny), ect.. I have to say, it drives better than ever, rides like a dream now once again, big thanks to Manny & Jenn (presure2), the Horniak(x_itchy_b_X), and Stef (hurley97). next is paint...and boost -------------------- |
Sep 4, 2009 - 11:22 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Hey guys; my belt actually snapped... broke right off... what the hell am I supposed to do for lining up the camshaft timing sprocket?? Do I just turn it to line up with the "U" notch??????
PLZ HELP I'm MID-REPLACEMENT AS I WRITE THIS.... ! -------------------- |
Sep 5, 2009 - 12:04 AM |
yes
Sep 5, 2009 - 12:09 AM |
I'm not going to screw anything up by doing that?? (timing wise)
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:31 AM |
