> ground wires on transmission, ??
post Mar 11, 2007 - 9:46 PM
95celly
Joined Feb 22, '07
From Philadelphia
i had to disconnect all my ground wires from the transmission to change my clutch and now i have to reconnect them but wasnt sure if it mattered exactly where they went since they are just ground wires. i know there are two in the front of the tranny, one of them being to ground for the batter but im not exactly sure which one it should be.
batter = battery
post Mar 11, 2007 - 11:52 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
put them back where they were, or if you have weird problems later remember what you did :-p
post Mar 12, 2007 - 1:16 AM
95celly
Joined Feb 22, '07
From Philadelphia
i dont remember exactly where each one went. my brother was helping me and he was the once disconnecting the ground wires. now i dont know where each one went. any help?
once=one
post Mar 12, 2007 - 1:26 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
There are two ground leads that are connected to the negative battery terminal. The shorter, thinner wire goes to a chassis ground right by the headlight and the longer, thicker gauge wire gets bolted down right in the middle of the top of the transmission. There is also one final thin ground wire that gets bolted between the starter and a chassis ground on the suspension tower.
This is how the GT and GT-Four are grounded, I'm pretty sure it's nearly the same, if not identical with the ST as well.
Lo-Fi Version Time is now: November 26th, 2024 - 4:58 PM
