> Is my convertible leaking? 95 GT, Water everywhere!
post Mar 12, 2007 - 2:01 PM
sh0x
Joined Jul 12, '06
From Minnesota
I have a 95 GT Convertible. I'm getting water in the rear driver's side cavity, where the rear quarter window rolls down into. It'll get so full it'll slosh around. Then it won't leak out, I have to stick a wet dry vac down there to suck it all out. Then it seems like if it gets too full it starts leaking onto the rear driver side floor, I had over an inch of water back there after a particularly bad storm. Killed a brand new $200 amp. But the passenger side is fine. Where should I look for this leak? Superficially everything looks fine. Thanks in advance for your help!
post Mar 12, 2007 - 9:23 PM
Velliety
Joined Jul 10, '06
From South Carolina
Mine has that too, drivers side only. The only thing I can figure out is that there are drain holes somewhere so the water should be able to drain out, but I guess that my driver's one got plugged with something. I can't find the drain hole itself to get the junk out of it.
Samantha
post Mar 13, 2007 - 8:09 AM
sh0x
Joined Jul 12, '06
From Minnesota
Thanks to 6gcelikas for this solution, our PM conversation follows.
6gcelikas: Check your drain holes they may be pluged
sh0x: Sounds like a good theory. Can you please tell me where these holes are and how I can access them? Do I need to remove the rear interior panel or just crawl under the car?
6gcelikas: They are on the bottom of the car ...where q-panel meets rocker panel. Sometimes they get pluged due to dirt or if some one did rustproofing.
Lo-Fi Version Time is now: November 23rd, 2024 - 8:18 AM
