Burning Oil |
Burning Oil |
Mar 13, 2007 - 7:13 PM |
Enthusiast Joined May 23, '06 Currently Offline Reputation: 0 (0%) |
I just changed my oil maybe 1200 miles ago. Today i was bored and decided to check how it, turns out Im only halfway to full, meaning my car is burning alot of oil. What could be causing this, i've never seen any smoke, and only occasionally do i beat on her.
Mar 13, 2007 - 9:40 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
QUOTE(terqui @ Mar 13, 2007 - 7:13 PM) [snapback]536028[/snapback] I just changed my oil maybe 1200 miles ago. Today i was bored and decided to check how it, turns out Im only halfway to full, meaning my car is burning alot of oil. What could be causing this, i've never seen any smoke, and only occasionally do i beat on her. Check for leaks near the head gasket or valve cover gasket. Also try checking if there are leaks from the oil pan gasket and drain bolt. -------------------- |
Mar 14, 2007 - 10:46 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
After that check your odometer. Engine wear will def cause you to burn oil. It's normal and I wouldn't make a big deal to replace the seals [other than the ones netrata stated above]. Most of the shaft seals can be conveniently replaced when you do other maintenance [ie Timing belt and clutch]. Toyotas leak period.
When you say you are half full - do you mean on the stamped part of the dipstick? that stamped part is equal to 1 quart. So you are probably only a half a quart low. Keep your eyes on her and replace the seals when it is most convenient. Or replace the seals now and do the timing belt, water pump, oil pum etc at the same time. Your engine will love you for it. This post has been edited by Negative: Mar 14, 2007 - 10:47 AM -------------------- |
Mar 14, 2007 - 12:59 PM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
no burning smell, no smoke, you sure your buring it and not leaking?
it could just be a leak lower on the engine so you wouldnt smell or see it. any spots on the ground under the car? This post has been edited by nightryder: Mar 14, 2007 - 1:04 PM -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Lo-Fi Version | Time is now: January 13th, 2025 - 12:52 AM |
