> sputtering problem, engine running rough
post Mar 13, 2007 - 11:36 PM
BlueCeliGT
Joined Mar 11, '07
From Barnesville, PA
So here's the deal...
When she starts up first thing in the morning she runs great. But as the engine warms up it has a rough idle(a bouncing effect) and when i hit the gas it'll sputter then catch but still not at full power. Cleaned the intake filter(aem cold air) changed plug wires and cap(no rotor tho), plugs are a month old and were pulled to have gaps checked. It started after we got a big snowstorm here a few weeks ago so i was thinking possibly a problem in the fuel system but looking for other ideas
Thanks
Eric
post Mar 15, 2007 - 7:29 AM
sapperk
Joined Mar 9, '03
From Orting, WA
I feel your pain, i have the same problem.
Things i replaced:
Airfilter, TimingBelt complete kit, Ignition Wires, Spark Plugs, Coolant with flush, Thermostat, and PCV Valve.
Next to try will be Throttle Sensor, Fuel Filter, and O2 Sensors both of them.
Any Advice?
post Mar 15, 2007 - 7:49 AM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
i just got that some prob fixed too...cost me 500 bucks. i needed a complete tune up- plugs, wires, filters, you name it i got it. that also includes a new head gasket and install of that so yeah.
post Mar 15, 2007 - 6:06 PM
BlueCeliGT
Joined Mar 11, '07
still no good, swapped out distributors and no change, ran it for codes yesterday amd still no luck. gonna let my uncle take a look at it tomorrow seeing how he is a certified mechanic and has his own garage. hopefully we can figure somethin out
post Mar 18, 2007 - 4:59 PM
BlueCeliGT
Joined Mar 11, '07
post Mar 18, 2007 - 9:24 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
IAC valve! Clean it and you will probably be happier. IAC = idle air control valve.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Mar 20, 2007 - 7:07 PM
sapperk
Joined Mar 9, '03
From Orting, WA
IAC Vavle ?
post Mar 20, 2007 - 8:15 PM
Agent21
Joined Sep 12, '05
Idle air control valve, Little electric assembly at the bottom of the throttle body. Hose it with CRC air intake cleaner.
94 GT Liftback
post Mar 21, 2007 - 4:55 PM
alltracman78
Joined Aug 9, '06
From Ma
Does it do it ALL the time when it's warmed up, or just some of the time?
post Mar 21, 2007 - 5:29 PM
sapperk
Joined Mar 9, '03
From Orting, WA
ALL THE TIME, mostly when it is warmed up though
post Mar 21, 2007 - 5:54 PM
alltracman78
Joined Aug 9, '06
From Ma
It could be the ISC [Toyota calls it a ISC -Idle Speed Control] valve. It certainly won't hurt to clean it out. Spray it down and scrub with a toothbrush or such. Spray/scrub the part that has the single vacuum line. Get that movable piece good and clean. That's for the air to flow. The part with 2 lines is a heater for the TB. Coolant flows through it. Don't worry about that.
Also don't lose the rubber seal for it.
But, if it's a constant, all the time surge up and down, there is also the possibility of a vacuum leak.
However, in your particular case I'm not quite as sure. Being OBDII, the ECU should be more sensitive to these things, and as such set the CEL.
However, you also have the 1st year of it, so it's not what it is now.
Also, having a pressure instead of flow based system [your engine uses a MAP sensor instead of a MAF to determine fuel supply] that might also desensitize the ECU......
There is one thing you might be able to try.
For at least the 92 - 95 5S there is a secondary, more sensitive diagnostic mode that can be used to help detect elusive problems. It's mainly to detect bad connections, but MIGHT work in this case too.
Locate the DLC1 [Data Link Connector, AKA diag box], and open it.
Locate TE2 [not TE1, TE2] and E1.
Using a paper clip or similar "tool", jump the two. Use one the right size. DON'T force too large a "tool" in there.
Now, drive your car above 6 MPH [below that will set a speed sensor code] around the block or such. Drive it for a few miles or until the CEL comes on. Make sure the engine is warmed up BEFORE performing this test.
Once you get back, jump TE1 and E1.
See if you have any codes.
This might or might not work on a 96^. Most likely it still will, but I can't promise. I'll try to remember to check at work tomorrow and see if it's listed in the BGB.
Sapperk, I didn't see that you had changed your cap/rotor in your list.
If not, and they're not in good condition, it certainly won't hurt to change them too.
I highly recommend OEM for them, NOT aftermarket.
www.1sttoyotaparts.com and www.partznet.com are two good online dealers that sell cheaper than normal dealers.
This post has been edited by alltracman78: Mar 21, 2007 - 5:56 PM
post Mar 21, 2007 - 6:24 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(alltracman78 @ Mar 21, 2007 - 10:54 PM) [snapback]538477[/snapback]
x2
post Mar 22, 2007 - 6:49 AM
alltracman78
Joined Aug 9, '06
From Ma
So
This gets a little bit interesting, to me at least.
There IS a check mode, even with OBDII, which probably explains why you don't have a CEL. To get some of the codes the ECU still needs to be put in the check mode, it isn't in it all the time like the newer OBDII.
The problem is, the BGB only lists the procedure for the scan tool. It has no mention of jumping TE2 and E1.
However, as long as you still have a TE2 terminal in your DLC1, I'm pretty sure that will put the ECU in check mode.
But, I CANNOT guarantee doing this won't cause a problem.
Understand there is nothing in the BGB specifically for this year about it.
I'm going on what I know about previous stuff, and making an educated guess.......
post Mar 24, 2007 - 12:14 PM
BlueCeliGT
Joined Mar 11, '07
well i swapped throttle bodies to see if it had any effect and it actually did have a big effect. now it seems to idle better(prolly due to a cleaner IAC valve). Still sputters sometimes but still running better
post Mar 29, 2007 - 5:03 AM
sapperk
Joined Mar 9, '03
From Orting, WA
I cleaned my throttle body, it runs much better but still some issues too.
post Mar 29, 2007 - 3:13 PM
nitrate
Joined Jun 20, '06
From Lancashire England UK
Hey All, I also have a 95 'First year GT' and my car also has these same really annoying symptoms. I've had them for around 6 months now and can't get to the bottem of things. The car does approx 100 miles per day on the M-way, and currently has 113K miles on the clock. I've tried to cure the symptoms for ages but nobody seems to be able to help!! frown.gif My symptoms are... Starts fine all the time, as soon as i set off the car seems jumpy, if i put the clutch in the idle seems to hunt for the correct idle, somtimes gets it so wrong it stalls. This can happen any time, wether hot or cold. I rekon i have about half the power i used to, and the car seems to be becoming sensitive to cold weather. Fuel consumption is up too. No obvious oil burning or leaks of any kind, no engine wear noises either, it just runs crap for a laugh i think. The only thing i can think of that i havnt tried yet is o2 sensors. Engine is a G3-SE, no fault codes either... CAN ANYONE PLEASE HELP US???
Cheers :-)
Leigh.P
P.S should there be a temp sensor in a hole in the side of my air box? Cos there has never been one there and when i got the car i just blocked up the hole???
This post has been edited by nitrate: Mar 29, 2007 - 5:00 PM
post Mar 29, 2007 - 5:07 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Hey All, I also have a 95 'First year GT' and my car also has these same really annoying symptoms. I've had them for around 6 months now and can't get to the bottem of things. The car does approx 100 miles per day on the M-way, and currently has 113K miles on the clock. I've tried to cure the symptoms for ages but nobody seems to be able to help!! My symptoms are... Starts fine all the time, as soon as i set off the car seems jumpy, if i put the clutch in the idle seems to hunt for the correct idle, somtimes gets it so wrong it stalls. This can happen any time, wether hot or cold. I rekon i have about half the power i used to, and the car seems to be becoming sensitive to cold weather. Fuel consumption is up too. No obvious oil burning or leaks of any kind, no engine wear noises either, it just runs crap for a laugh i think. The only thing i can think of that i havnt tried yet is o2 sensors. Engine is a G3-SE, no fault codes either... CAN ANYONE PLEASE HELP US???
Cheers :-)
Leigh.P
Technically the GT has been around for a very long time, and 95 is not the first year GT for the 6th Gen. 94 is. Secondly your engine is not G3-SE, it is 3S-GE. tongue.gif
Now that that is all cleared up, have you tried resetting the ECU? I was having the same problem a year or so ago and it was from when I disconnected the battery and did not give the ECU time to relearn.
Basically try unhooking your battery. Let it sit for a while, then come back and reconnect it. Start the car and let it sit. Take it for a drive after sitting for a while. Does it behave better?
**** Photobucket
post Mar 30, 2007 - 11:35 AM
nitrate
Joined Jun 20, '06
O.K, I'll try resetting the ECU in the morning and let you know if it makes a difference. If it doesn't i really dont know what to do, The MOT is up in a few months so i don't know whether or not it will be worth taking it through if these problems persist. Still don't know if i should have a temp sensor in the air filter box... anyone know??
Cheers
Leigh.P
post Mar 31, 2007 - 5:24 PM
alltracman78
Joined Aug 9, '06
From Ma
Hm.
I believe you have a MAP based system.
In which case yes, it's very possible. Especially if there is a small round hole in the side of the box.
Your first step is to confirm you're supposed to have one there [a pic of the hole and surrounding area would help].
Your second step, assuming there is supposed to be one there, is to locate it, and reinstall it.
Also, a GOOD fuel injection flush/cleaning will probably help some.
How do the plugs/cap/rotor look?
post Apr 5, 2007 - 9:04 AM
nitrate
Joined Jun 20, '06
Reset the ECU... left power off for over an hour. This had no effect at all, the car just idled high for a while while it re-learnt its settings. My plugs are in excellent condition considering i've never changed them, funny pointy needle tips... cap and rotor are good, leads i'm assuming are also fine. Just cannot seem to get to the bottem of this one. I have a crack in the exhaust right at the back at the back box manifold, i dont suppose a leak so far back can be causing these problems?
Leigh.P
Lo-Fi Version Time is now: February 22nd, 2025 - 8:19 AM
