> how do i get the power to the wheels?
post Mar 13, 2007 - 11:51 PM
duce135
Joined Jun 14, '06
From New Mexico
Ok my 5sfe is currently at 17 psi of boost with the burien kit. i been having it for bout 2 years and now the cluctch is slipping in third gear. Any one have any suggestion of what type of clutch is good? n also flywheels while im at it.
post Mar 14, 2007 - 1:04 AM
6strngs
Joined May 12, '06
From Wilmington, NC
is that a typo? did you mean 7 PSI?
anyway. I have a fidanza lightweight flywheel and I love it. it made a big difference! as for clutch, I've got a spec stage 2 and haven't had any problems, but other people on here say they have. ACT makes good clutches.
post Mar 14, 2007 - 10:06 AM
Negative
Joined Apr 28, '04
From Houston, Texas
ACT clutches are faultless. I've had them in all my Celicas and not one problem so far. I've heard mixed results with the other brands. I'd go ACT to be sure about it.
He must mean 7PSI. 17PSI for two years = Destroyed 5S I would think.
post Mar 14, 2007 - 10:56 AM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
QUOTE(Negative @ Mar 14, 2007 - 11:06 AM) [snapback]536171[/snapback]
Celica ST202
post Mar 14, 2007 - 11:58 AM
QUOTE(Rockford @ Mar 14, 2007 - 11:56 AM) [snapback]536189[/snapback]
post Mar 18, 2007 - 1:51 AM
duce135
Joined Jun 14, '06
From New Mexico
I know to my suprise and to your suprise but my car been running 12 for two years and 17 the past three months with the Burien set up... It's not a typo!!!
post Mar 18, 2007 - 1:56 AM
duce135
Joined Jun 14, '06
From New Mexico
and oh yeah... still stock internals unless the old couple before me change it to forged pistons...
post Mar 18, 2007 - 2:55 AM
Hanyo
Joined Aug 16, '03
From Bay area
off topic: wow what hood scoop is that?
post Mar 18, 2007 - 2:15 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(duce135 @ Mar 17, 2007 - 11:51 PM) [snapback]537254[/snapback]
have you added anything to the burien set-up. i.e. an intercooler or water/methanol injection? also, do you know what kind of power you are putting down and/or 1/4 mile times?
post Mar 18, 2007 - 11:50 PM
duce135
Joined Jun 14, '06
From New Mexico
Nope... I added a front mount intercooler, same 360cc injectors and a 3 inch custom exhaust... Im hoping to get it to the dyno this season but the last time i was at the track i ran a 15 flat at 7 psi cause of a big boost leak... remember Im at very high elevation (New mexico)... probably low 14 at lower elevation... Im goin to take it to the drag once i get my clutch in...
post Mar 19, 2007 - 12:12 AM
QUOTE(Hanyo @ Mar 18, 2007 - 3:55 AM) [snapback]537264[/snapback]
Looks 5gen Alltrac.
Strong clutch, LW flywheel, LW wheels.
post Mar 19, 2007 - 12:29 AM
6strngs
Joined May 12, '06
From Wilmington, NC
well, that just makes me think that possibly the 5sfe is capable of more than we ever thought... one day I plan on building a super 5sfte with all forged internals, big cams, big turbo, and lots and lots of boost wink.gif right now I'm trying to build a very modest 5sfte set-up using a stock ct-26 from an mr2 turbo.
post Mar 19, 2007 - 1:06 AM
17 psi on the burien kit seems kinda high. It just seems pretty unlikely that you could run 17psi on a kit designed to run about 7psi...with only a FMIC and exhaust added on...
you didn't meantion a fuel pump or any sort of EMS... ? boost controller...? got a boost gauge ?
pics would be great
post Mar 19, 2007 - 1:21 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Batman722 @ Mar 18, 2007 - 11:06 PM) [snapback]537513[/snapback]
pics would be great
I hope you don't mind me posting these, just a couple pics I've found from your previous posts.
post Mar 19, 2007 - 5:20 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
wider tires, stickier rubber, limited slip differencial, taller final drive
edit: ...sorry ... wrong answer
i've never put in an aftermarket clutch so i can't give you advice... i'd point you towards centerforce dual friction or star/spec clutches... but that's based on internet hear say rather than first hand experience
This post has been edited by NuclearHappineS: Mar 19, 2007 - 5:24 AM
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Mar 19, 2007 - 2:34 PM
hate to tell you this, but you dont have the fuel to run 17 psi. chances are the motor will not last too long at the current boost level
post Mar 19, 2007 - 4:30 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
What kind of fuel management do you have to control the injectors? You must have some bad-ass fuel management to run 17 psi.
94 Celica gt white (sold)
post Mar 19, 2007 - 10:56 PM
duce135
Joined Jun 14, '06
From New Mexico
I got a boost gauge and an air fuel ratio gauge... my air fuel is reading at about .879... my boost is at 12 first gear, 17 second and third never really have a chance to read cuz the clutch is out.... i dont have any type of boost controller... the only thing controlling my boost is the by pass valve... all i did was get the red spring which is rated from 14-20 psi depending how much i turn the bolt down... still on stock fuel pump, 360cc injector.. the only thing ever broke on me was my coil from the distrubutor... i got no traction at all first and second gear.... i beat my friend stage 2 srt 4 and some what hang with another friend mr... loving the 5s.... heheh
yup the picture above is from my recent accident and almost sold it... and yeah this is the 3rd time i bring it back from the junk yard....
i got the hood scoop from a subaru... dont really remember the name of the car... but yup... it's jux a 94 gt
QUOTE(bccentaur3 @ Mar 19, 2007 - 4:30 PM) [snapback]537746[/snapback]
stock fuel... accept for the 360 injectors
QUOTE(lagos @ Mar 19, 2007 - 2:34 PM) [snapback]537698[/snapback]
i know i know... jux the matter of time... but i jux check my compression and still at around 150 psi
QUOTE(6strngs @ Mar 19, 2007 - 1:21 AM) [snapback]537515[/snapback]
pics would be great
nope not at all... that was from the accident i had...
post Mar 19, 2007 - 11:10 PM
6strngs
Joined May 12, '06
From Wilmington, NC
wow, so, 17 PSI on a stock 5s, with no fuel management, stock fuel pump, and 360cc injectors... I'm amazed you haven't blown that motor yet! you'd have to be running extremely lean!
post Mar 19, 2007 - 11:34 PM
that "air to fuel ratio" gauge you have cant not tell you what your air to fuel ratio is. you realize that, right? in order to monitor your a/f ratio you need a wideband. but somehow i think that this advice will fall on def ears.
Lo-Fi Version Time is now: February 17th, 2025 - 12:26 AM
