2 Pages V  < 1 2
> how do i get the power to the wheels?
post Mar 20, 2007 - 1:04 AM
ice23q
Joined Jan 16, '04
From sydney australia
Some how i cant see you having 17lb on a stock 5sfe. The only way is if you drive like a granny.... I had my 5sfe running 12lb and blew it up. I did drive it hard every day so that didnt help.
my boost is at 12 first gear, 17 second and third never really have a chance to read cuz the clutch is out.... i dont have any type of boost controller
How can you have a different boost level through the gears with no boost controller.????
I would sugest you turn your boost down before you catch the bus to work....
312whp with more to come....
post Mar 20, 2007 - 6:02 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
even on the gauge you have....you want to be seeing something in the 0.92 to 0.94 range...0.87 is most likely on the lean side of things...but it will vary depending on where the o2 sensor is mounted.
his boost controller is the wastegate spring which seems to be set to 17psi from what he describes. The stock 6G gearing is short. This means that the car is out accelerating the turbo.. So he's not building full boost to 3rd gear.
just to give you an idea (IIRC)
0.87 O2 is around 13.5:1 ,
0.93 O2 is around 12.5:1 ,
0.96 O2 is around 11.5:1
If you want to keep running this boost/power level. I would recommend a meth injection kit with a 3.24 GPH nozzle...and of course a better clutch to hold the power
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Mar 22, 2007 - 12:58 AM
duce135
Joined Jun 14, '06
From New Mexico
LOL... jux a matter of time before the motor gonna be gone so i can get the 3SGTE.... way more potential to satisfy my need for boost...
post Mar 22, 2007 - 3:27 PM
QUOTE(ice23q @ Mar 20, 2007 - 2:04 AM) [snapback]537914[/snapback]
This is normal.
post Mar 22, 2007 - 4:13 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I don't get this, you're boosted with the only injectors as fuel upgrade with NO check engine light?
94 Celica gt white (sold)
post Mar 31, 2007 - 12:02 AM
duce135
Joined Jun 14, '06
From New Mexico
I have a map sensor upgrade so that my computer will only read 2psi of boost... ill take it to the drag this sunday and the new ACT iz coming... ill let you guyz know how i would run...
post Mar 31, 2007 - 12:48 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Get some vids.
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 23rd, 2024 - 3:39 AM
