Enthusiast ![]() ![]() Joined Apr 29, '03 From lynn,ma Currently Offline Reputation: 0 (0%) ![]() |
when putting the rotor on... and securing the caliper mount ... should the rotor be tight on or does it still jiggle? like not even tightly on there?
Enthusiast ![]() Joined Dec 28, '05 From Norway Currently Offline Reputation: 0 (0%) ![]() |
It should jiggle a bit, when you put your wheel on, it will be tight.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
heres a tip, put rotor on, use 2 lugs to tighten in place, put caliper on. take lugs off, put tire on and lug.
thanks, first time doing this and wasn't sure how it was suspose to act.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Put some antiseize or wheel bearing grease on the hub under the rotor.
It will keep it from rusting to the hub. -------------------- ![]() |
about the calipers... it has 2 V shaped springs to hold/push the pads apart, but my driver side only has one. anyone know where to get it, or do i have to go to the dealer for them? or do i really need them at all?
$20 at an autoparts store for the clip and hardware kit, it will include them, theyre not needed but help prevent the pads from dragging a little and mostly help the stop noises.
Lo-Fi Version | Time is now: February 12th, 2025 - 3:53 PM |
