to the track i go! (for real this time), Results inside |
Mar 17, 2007 - 1:02 PM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
whats up guys, im getting ready to go to the track tomorrow. any suggestions? waterbox tips? launch suggestions?
just curious what i will run been wondering for a while. wish me luck! This post has been edited by easternpiro1: Mar 18, 2007 - 8:08 PM -------------------- |
Mar 17, 2007 - 6:02 PM |
QUOTE(easternpiro1 @ Mar 17, 2007 - 1:02 PM) [snapback]537102[/snapback] whats up guys, im getting ready to go to the track tomorrow. any suggestions? waterbox tips? launch suggestions? just curious what i will run been wondering for a while. wish me luck! if your running street tires, go around the waterbox. if anything just spin them once around to kick the dirt and rocks off them. just lower your air pressure in the fronts, crank up the rears, launch soft, and hit it hard!!! (you'll just spin the tires if you really rev it before launch...you'll have to find the sweet spot for your own car.) GOOD LUCK!! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Mar 17, 2007 - 7:48 PM |
just give them a little spin to clean them
run about 26-30psi in your front tires biggest tip is learn how to slip the clutch out off a launch hard to teach via a post but, i'd probably say some where between 2k and 2,500 rpm hold at the light then slip the clutch out while giving it gas....abuses the clutch some but if you can do it right, you'll end up full boosting maintaining traction and getting good 60' times... just remember a drag race is won and lost on the launch concentrate on getting them down really good and lowering your 60' times as much as possible...a realistic goal for your 60' foot times are like 2.2 to 2.3 seconds |
Mar 17, 2007 - 7:56 PM |
thanks! what about spin later on? i will almost certaintly spin in 2nd (got my tires 3-4 weeks ago and theyre starging to give a bit)
Mar 17, 2007 - 9:42 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
With the change in tire pressure it should reduce the tire spin. Since you will most likely spin in 2nd, I would say slip the clutch, But there might be better ways.
Mar 18, 2007 - 7:18 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
so... how did it go??? :-)
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Mar 18, 2007 - 8:07 PM |
okay im back! I did HORRIBLE on my first try. it was bad. I thought my clutch went out on me after i tried to launch off the start. i was told i had white smoke coming out of the back (BOTH have never happened before) i cant begin to know what happened with that.
then I finally got better at my reaction time (my best was a .14something) and my best quarter mile time was 14.2 i was hoping i would get at least around 13.6 It seemed that when I nailed the react time i would miss a gear later or just loose traction. i was using my street tires (205 40 17's) oh and i later lowered my tire pressure. i think my axles are going bad. im feeling/hearing a light clunk in my floorboard when i am accelerating lightly and letting of the gas. anybody know what that is? -------------------- |
Mar 18, 2007 - 8:16 PM |
does your car shake horrible at high speeds?
what did you get for 1/8? 60ft? |
Mar 18, 2007 - 8:45 PM |
QUOTE(jdg371 @ Mar 18, 2007 - 8:16 PM) [snapback]537404[/snapback] does your car shake horrible at high speeds? what did you get for 1/8? 60ft? no it dosent seem to shake much at a high speed. overall in the 60ft i was getting in the mid 2s (was REALLY babying it on the line) and in the 1/8 i was always in the mid to high 9s my best 1/8 was 9.4sec by the way my first run was a 17 This post has been edited by easternpiro1: Mar 18, 2007 - 8:46 PM -------------------- |
Mar 18, 2007 - 9:11 PM |
Your first run would still beat auto STs!
Great run overall dude. 14.2 is pretty good since you haven't really drag raced much.. did better than my expectations [no offense...] I thought you would hit mid to hi 14s |
Mar 18, 2007 - 9:30 PM |
umm 2nd gear spin is solved with proper throttle control, you have to ease into it and not floor it
put those 14s on that i gave you and run 26psi in air pressure should help with the launch practice more is always important, overall not a bad start i run 14.3 with a 2.1 60' in the jetta on a good run so you still beat me doing crappy...JERK! aim for a 2.1 or 2.2 60' time and you'll see massive overall ET's improve A LOT |
Mar 18, 2007 - 9:32 PM |
14s in the front with 17s in the back would help with launching. Making the rear stiff to prevent it from "poping"?
Mar 19, 2007 - 8:29 AM |
sorry plyr. i was didnt get the chance to get the tires the store was closed by thetime i got there should have went to wally world lol
but aobut that noise? what could it be? -------------------- |
Mar 19, 2007 - 10:16 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
Awesome Piro! If you get some experience with the track and better tire/rim situation I know you'll be hitting your goal or better.
EDIT This post has been edited by Negative: Mar 19, 2007 - 10:18 AM -------------------- |
Mar 20, 2007 - 12:37 AM |
Enthusiast Joined Apr 16, '05 From Orlando, FL Currently Offline Reputation: 1 (100%) |
so just for self reference..with the proper launch, he should be running mid 13's..am i right when i say that?? please correct me if im wrong..
Mar 20, 2007 - 1:00 AM |
QUOTE(easternpiro1 @ Mar 18, 2007 - 9:07 PM) [snapback]537400[/snapback] okay im back! I did HORRIBLE on my first try. it was bad. I thought my clutch went out on me after i tried to launch off the start. i was told i had white smoke coming out of the back (BOTH have never happened before) i cant begin to know what happened with that. then I finally got better at my reaction time (my best was a .14something) and my best quarter mile time was 14.2 i was hoping i would get at least around 13.6 It seemed that when I nailed the react time i would miss a gear later or just loose traction. i was using my street tires (205 40 17's) oh and i later lowered my tire pressure. i think my axles are going bad. im feeling/hearing a light clunk in my floorboard when i am accelerating lightly and letting of the gas. anybody know what that is? welcome to owning a 13 second car, but never being able to prove to anyone that you do! hahaha -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 20, 2007 - 11:11 AM |
its not a 13 second car if he can't drive it to 13 seconds.......
Mar 20, 2007 - 7:41 PM |
QUOTE(playr158 @ Mar 20, 2007 - 12:11 PM) [snapback]538004[/snapback] its not a 13 second car if he can't drive it to 13 seconds....... right. but ask anyone who owns one and they will tell you that these cars are a lot faster on the street then what their 1/4 numbers show. 14.2 is probably what a stock WRX would do, yet we can take them out with no problem. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 20, 2007 - 11:33 PM |
stock wrx is way slower then 14.2
but lol running around being like my car is faster then it says on the paper! doesn't help you at all....your only as fast as you can drive it street or strip....i've driven several 3sgte swapped celicas 5th and 6th gen including this car (piro) the car is no doubt capable of being faster then 14.2 BUT it isn't until actually proven....words don't mean anything without the proof.. just like making a 1500hp supra and saying this car can do 8.742 seconds in the 1/4 mile and top speed @ 215....well if every driver has only achieved a 9.16s 1/4....its only a 9.16s car.....making comments based on speculation isn't a sound comment or wise decision oh and i would LOVE to see someone run a faster 1/4 on the street then on a prepped track..that make sense This post has been edited by playr158: Mar 20, 2007 - 11:34 PM |
Mar 21, 2007 - 12:30 AM |
Enthusiast Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
So why dont any of you guys who spend all this money on engine swaps buy slicks? Everyone has traction problems but no one buys slicks!
Lo-Fi Version | Time is now: January 9th, 2025 - 6:56 PM |
