> Identifying some engine parts
post Mar 17, 2007 - 6:36 PM
Mangozac
Joined Mar 13, '07
From Gold Coast, QLD, Australia
Hi guys,
I started planning for my CAI install (I haven't bought the parts yet - I'm just measuring everything up and seeing where things will fit so I can get the tubing custom bent).
Unfortunately I didn't get very far as I'd left my good tool kit at Mum and Dad's so gave up after a little while of not having the right tools. I hate havign crappy tools!.....
OK so the main thing I want to identify is this (in yellow):
It is some kind of box attached to the air intake. It has not other connections so I assume it will be fine to not have it there when I replace the intake. But I would just like to know what it is....
I also discovered that the ribbed section has split again kindasad.gif I only glued that up with silicone a few weeks ago.
Also, soo that little fitting sticking out on the left side of the intake pipe just near the throttle body? I only just noticed that it isn't connected to anything and is therefore suckign air straight in from the engine bay kindasad.gif
The intake air temp sensor mounts on the filter box. Will it be fine to relocate that to close to the throttle body when I install the CAI?
And whilst I was at it I figured I might quiz the knowledgable on some other parts that I don't have the best understanding of wink.gif
1. Line from the intake pipe to the valve cover.
2. The unattached fitting I was talking about.
3. No idea what this is.
4. The wierd box on the intake pipe from the previous picture.
My throttle cable has a lot of slack in it (you can see in the last picture). The adjustment point where the cable exits the sleeve is at maximum adjustment but it still has a heap of slack that causes the accelerator to stick sometimes when you first apply pressure. Any suggestions of how to fix that. I played around with where the cable attaches to the throttle with no success...
And one very last thing! I promise! According to specs I should have a drivers airbag. I was playing around behind my instrument panel yesterday (with the battery disconnected so I couldn't trigger the airbag) and decided to check out the airbag. I couldn't work out how to prise the centre of the steering wheel off but from peering through the side I couldn't see any airbag.
The SRS light on the instruments has never come on so after reading the repair manual I checked the SRS-IND fuse which is blown. I'll go and get a new one today but I'm still concerned about the lack of airbag...
The car has been in some kind of prang at some stage. I'm wondering if the airbag deployed then and they just pulled it out rather than replacing/fixing it.
That's all! Thanks for reading!
Zac
post Mar 17, 2007 - 6:47 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
freaking owned!
This post has been edited by devilsden97: Mar 18, 2007 - 12:29 AM
Kawi Love
post Mar 17, 2007 - 7:34 PM
that is a resonator. All it does is change the sound of your intake to your engine. It is used to make the engine quieter and be no real difference if you remove it. If you do remove it, you would need to plug up the hole, you can use the top of a vitamin/pill bottle wink.gif
post Mar 17, 2007 - 9:50 PM
alltracman78
Joined Aug 9, '06
From Ma
1-PCV [Postive Crankcase Ventilation] hose.
Engine vaccum sucks the pressure from inside your engine. Lowers HC [HydroCarbon] emissions and helps prevent oil leaks.
2-Probably a bracket for another market. The US spec 3SGTEs come with the brackets for RHD throttle cables. At least on the ST185.
3-EGR [Exhaust Gas Recirculation] valve and EGR modulator. As well as assorted vacuum lines for said valve/mod. Which has absolutely nothing to do with the throttle body.
EGR simply allows exhaust gas to flow into your intake manifold under certain conditions. This lowers NOx. The modulator helps to regulate how much EG flow into the engine there is. If either is bad it can cause a rough idle or kill the engine.
post Mar 18, 2007 - 12:28 AM
devilsden97
Joined Jun 13, '05
QUOTE(alltracman78 @ Mar 17, 2007 - 10:50 PM) [snapback]537211[/snapback]
i got owned.
Kawi Love
post Mar 18, 2007 - 5:28 AM
Mangozac
Joined Mar 13, '07
alltracman, thanks for the descriptions, they were much appreciated.
Batman, I thought it may be a resonator but didn't think they were so far back in the system.
Thanks for your help guys!
post Mar 18, 2007 - 6:58 AM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(devilsden97 @ Mar 18, 2007 - 12:28 AM) [snapback]537239[/snapback]
i got owned.
It's all good man.
QUOTE(Mangozac @ Mar 18, 2007 - 5:28 AM) [snapback]537275[/snapback]
post Mar 18, 2007 - 11:44 AM
that is just a breather like Migga said, the PCV is actaully right next to the throttle cable bracket (the ? shaped hose)
post Mar 18, 2007 - 2:02 PM
alltracman78
Joined Aug 9, '06
From Ma
The breather hose is part of the PCV system.
The PCV VALVE [though I don't know if non US spec engines got an actual valve or not] and hose are that ? shaped hose by the throttle linkage.
Lo-Fi Version Time is now: February 20th, 2025 - 1:52 PM
