![]() Enthusiast ![]() ![]() Joined Jan 10, '07 From Devon, UK Currently Offline Reputation: 0 (0%) ![]() |
Well, I've had the bits sitting in my garage to lower the car for ages and finally a friend of mine Tom and I got round to doing it yesterday. As the car has superstrut it was rather err "fun" to do.
What do you think guys? Super Strut Hell ![]() The end result was worth it though I think ![]() ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
looks nice! I love your rims!
![]() Enthusiast ![]() Joined Jan 27, '07 From Swindon/England Currently Offline Reputation: 0 (0%) ![]() |
Looks Brill!
![]() -------------------- ![]() Celica-Club.co.uk - Best Show Car JAE '06 Celica-Club.co.uk - Best Gen 6 JAE '07 Celica-Club.co.uk - Members Best Celica JAE ‘07 |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) ![]() |
more pics
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) ![]() |
that's a hot car !
-------------------- ![]() -Rémy 02 SiR, 08 250R |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
Looks Great!! Its a good feeling to have it lowered...... literally. :-D
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Enthusiast ![]() ![]() ![]() Joined Jul 6, '06 Currently Offline Reputation: 1 (100%) ![]() |
do you ahve like fender flares on the rear?
-------------------- ![]() KB |
QUOTE(KB-2 @ Mar 20, 2007 - 3:35 AM) [snapback]537876[/snapback] do you ahve like fender flares on the rear? No, just the standard body - must be a trick of the angle I took it at ![]() QUOTE(DSToyo @ Mar 19, 2007 - 5:32 PM) [snapback]537632[/snapback] more pics ![]() Your wish is my command - always glad to post more pics ![]() ![]() ![]() ![]() And one of my new LikwidArt Toyota badges ![]() ![]() This post has been edited by BigAl_UK: Mar 20, 2007 - 3:32 AM |
![]() Enthusiast ![]() ![]() Joined Jan 6, '05 From Finland, Turku Currently Offline Reputation: 0 (0%) ![]() |
It really makes a big difference when you lower your celi. Our cars are like cross country models with stock suspension.
![]() -------------------- Please visit on our teams new website. hrp-tuning.com
![]() 19in deepdishes - invader bodykit - invader cf hood - x-box - dls audio |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
nice!
what tire size is that? |
QUOTE(Hanyo @ Mar 21, 2007 - 4:12 AM) [snapback]538234[/snapback] nice! what tire size is that? 215/40 R17 Toyo T1-R ![]() Thanks for the kind comments guys ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) ![]() |
nice
![]() Enthusiast ![]() Joined Dec 15, '06 From Lithuania, Europe Currently Offline Reputation: 0 (0%) ![]() |
Looks great! Please, give more details about lowering Superstrut!
QUOTE(G3D45 @ Mar 21, 2007 - 10:27 AM) [snapback]538288[/snapback] Looks great! Please, give more details about lowering Superstrut! ![]() OK, I used Espiler 40mm lowering springs which came from Yahoo Japan auctions. The lowering process is the same as a non superstrut car for the back but it might be worth replacing the rear anti-rollbar drop links as they are cheap and prone to damage when disconnecting them. Also, don't forget to disconnect the brake line holders from the struts/ For the front the first thing is to remove the nut that hold the hub on so you don't pull the drive shaft out - you will need a new split pin for when refitting. Then you have to split the figure of 8's which will probably require a large hammer and a big pry bar. Then disconnect the brake pipe carriers on the stut. Split the upper ball joint with a ball joing splitter. Then the hub should swing free (might be a couple more bolts but should be obvious). Once you have done this stage undo the top mount bolts not forgetting to support the strut when you do this - warning, the superstrut front struts are very heavy! We got the driver side out no problem but on the passenger side we had to disconnect the brake line in order to get the strut out. Once the strut is out compress the spring with a spring compressor and undo the top nut. Compress the new spring in a spring compressor and refit the various top bits. Greasing the top and bottom of the spring should stop them squeaking ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 13, '04 From Sydney/Australia Currently Offline Reputation: 2 (100%) ![]() |
looking good -R
-------------------- ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife |
QUOTE(BigAl_UK @ Mar 21, 2007 - 12:50 PM) [snapback]538291[/snapback] QUOTE(G3D45 @ Mar 21, 2007 - 10:27 AM) [snapback]538288[/snapback] Looks great! Please, give more details about lowering Superstrut! ![]() OK Thanks ![]() ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
looks good Al. makes a big difference in looks.
Enthusiast ![]() ![]() Joined Apr 29, '03 From socal Currently Offline Reputation: 0 (0%) ![]() |
nice. whats the drop on your celi?
QUOTE(trdcelica94 @ Mar 23, 2007 - 4:43 AM) [snapback]538960[/snapback] nice. whats the drop on your celi? 40mm - I guess that's roughly 1.6 inches to you guys though ![]() ![]() **EDIT** I have to say that the springs I used make the ride so much more comfortable than the standard springs as well as the improved looks and handling. I think it's because the standard SS springs only have a few coils where as the new ones have loads ![]() This post has been edited by BigAl_UK: Mar 23, 2007 - 3:27 AM |
Lo-Fi Version | Time is now: February 25th, 2025 - 2:11 PM |
