Key Off Power Windows, Door Lock Control relay |
Mar 21, 2007 - 11:47 PM |
Enthusiast Joined Apr 11, '06 From Tasmania Currently Offline Reputation: 0 (0%) |
Trying to find out more info about the key off power windows.
Have been reading th 95 wiring manual, and come across this statment: FOR ABOUT 60 SECONDS AFTER THE IGNITION SW IS TURNED OFF, IT IS POSSIBLE TO RAISE AND LOWER THE POWER WINDOW BY THE FUNCTIONING OF THIS RELAY. I want this! any of you guys 6gc do this and if so can we try and find out if it is as simple as swaping relays over. i will try to get some photos of my relay to compair to somone elses. -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Mar 22, 2007 - 7:12 AM |
Enthusiast Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
is there any need? just put the key back in and switch the ignition back on dude.
Mar 22, 2007 - 9:13 AM |
Enthusiast Joined Mar 16, '07 From the gap that lies between one microsecond and the next... Currently Offline Reputation: 0 (0%) |
Some electrical components will remain operational for a short time as long as a door is not opened. Your windows may already be part of this system. You may want to test these circumstances before you begin ripping things apart looking for that relay.
-------------------- The poster is not bound by any accuracy, stated or implied, of the previous post. Any similarities to actual people, fictional or real, may or may not be a coincidence.
--applejax |
Mar 22, 2007 - 9:47 AM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(applejax @ Mar 22, 2007 - 2:13 PM) [snapback]538699[/snapback] Some electrical components will remain operational for a short time as long as a door is not opened. Your windows may already be part of this system. You may want to test these circumstances before you begin ripping things apart looking for that relay. This is the way mine is wired. Also it seems to last for longer than a min but I have never clocked it or anything. It will stop if you open the door or after some specific period of time. I thought my '95 GT also did this but I could be wrong. -------------------- |
Mar 22, 2007 - 5:05 PM |
Enthusiast Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Yeah my Celica does that and my 96 Camry does too, but you can't open any doors. Just turn off the car and then adjust your windows without opening the door.
My girlfriend opens the door on me all the time when I'm closing my window this way. >< -------------------- |
Mar 22, 2007 - 5:07 PM |
QUOTE(vsideboy @ Mar 22, 2007 - 7:12 AM) [snapback]538668[/snapback] is there any need? just put the key back in and switch the ignition back on dude. thats why i want it, i am sick of leaving the windows down and turning the car off, than having to turn it back on. And my celica is 94 and i belive one of the first in Australia. when i turn off the key the power is off, only power is the light around my ignition. open the door and the same. -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Mar 22, 2007 - 7:10 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
my st has that - i put an alarm system on it so now i can control the windows form a remote anytime, if you have a use to use your windows like that its not tooooooo hard, but it is a little time consuming. depends on how much its worth to you
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Mar 22, 2007 - 7:39 PM |
Is mine the only one not to have this, or you think that my relay is burnt doors still lock and windows still move,
any aussie SX's have this? jason that sounds so cool what you have done with your remote, do they go down only in that 60sec or any time you push the button. -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Mar 25, 2007 - 8:15 PM |
Any one got any more info
Mar 25, 2007 - 10:11 PM |
they go down whenever - from like 3000+ feet away they work supposedly, 200ft away inside an office building i can crack them in 1" increments, or put them all the way down, put them all but 4" down (how i like to drive with em down instead of fully down) or put them up - also if i have them down and arm my alarm it automatically puts the windows up
time wise though - after having the key out for like 8 hours in at work i hit the lil button n they go down but when in the car before the door is opened they are still on the whatever second timer - just so my battery isint drained that much need any help i should be able to help you out, i still have pages upon pages of wiring diagrams, copied a dvd from a friends shop of all wiring diagrams/maintenance repair procedures etc for this car, so anything you need hit me up -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
Mar 26, 2007 - 4:00 PM |
Enthusiast Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
my car has this
...i never knew that |
Mar 28, 2007 - 10:10 PM |
Weird. Keep on Hearing about people with this
any without. it will be alot quicker if i just have to get the same part. any one know it the 5GC's did this Thanks for all your input -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Lo-Fi Version | Time is now: December 4th, 2024 - 5:25 AM |
