low offset wheel fitment on celica..., 18x8 +30 offset wheel with a 225/35/18 tire + 1.75 drop + roled fender |
Mar 22, 2007 - 1:09 PM |
Enthusiast Joined Dec 22, '06 From Pembroke Pines, Florida Currently Offline Reputation: 0 (0%) |
like the disescrisiption says, is"18x8 +30 offset wheels with a 225/35/18 tire, 1.75 drop and roled fenders" going to rub??? my mesurements says no rubb!!! others have told me that it will rubb...what is your opion??? it this too much offset???
This post has been edited by supradog1: Mar 25, 2007 - 11:15 PM |
Mar 22, 2007 - 7:02 PM |
Should be fine...
http://www.6gc.net/forums/index.php?showtopic=32534 EDIT: As long as you roll your fenders. There should be plenty of clearance on the back side. This post has been edited by WannabeGT4: Mar 22, 2007 - 7:04 PM -------------------- Project ST204.5 99.88946% complete... |
Mar 23, 2007 - 1:32 AM |
That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock.
Mar 23, 2007 - 9:32 AM |
QUOTE(Bigmeanbulldog55 @ Mar 23, 2007 - 12:32 AM) [snapback]538990[/snapback] That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock. You are wrong. -------------------- Project ST204.5 99.88946% complete... |
Mar 23, 2007 - 9:54 AM |
QUOTE(WannabeGT4 @ Mar 23, 2007 - 9:32 AM) [snapback]539023[/snapback] QUOTE(Bigmeanbulldog55 @ Mar 23, 2007 - 12:32 AM) [snapback]538990[/snapback] That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock. You are wrong. Come on Wannabe, it might stick out a tone if he squeals his tires going around a curve. This post has been edited by jgreening: Mar 23, 2007 - 9:55 AM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 23, 2007 - 1:01 PM |
QUOTE(jgreening @ Mar 23, 2007 - 9:54 AM) [snapback]539027[/snapback] QUOTE(WannabeGT4 @ Mar 23, 2007 - 9:32 AM) [snapback]539023[/snapback] QUOTE(Bigmeanbulldog55 @ Mar 23, 2007 - 12:32 AM) [snapback]538990[/snapback] That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock. You are wrong. Come on Wannabe, it might stick out a tone if he squeals his tires going around a curve. so will this offset work or not in your opion??? I think it will, according to the offset chart you can run +28 stock hight and +40 with droped hight, so if you run +30 offset with roled fenders you will be left with 2mm clearence... this is the optimum offset for maximum wheel lip that you can fit on our cars with out rubbing... (ie, only with the wheel, tire and drop specs givin above...) This post has been edited by supradog1: Mar 25, 2007 - 11:21 PM |
Mar 23, 2007 - 2:33 PM |
QUOTE(Bigmeanbulldog55 @ Mar 23, 2007 - 6:32 AM) [snapback]538990[/snapback] That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock. Our stock offset is +35 ish. -35 is is like... WHOA NUTS! The wheels will be sticking several inches out from the fender. QUOTE(supradog1 @ Mar 23, 2007 - 6:01 PM) [snapback]539110[/snapback] so will this offset work or not in your opion??? I think it will, acording to the offset chart you can run +28 stock hight and +40 with droped hight, so if you run +30 offset with roled fenders you will be left with 2mm clearence... this is the optimum offset for maximum wheel lip that you can fit on our cars with out rubbing... (ie, only with the wheel and tire specs givin above...) 18x8 with a 30mm offset is pushing it very very close. I tend to think it'll rub on the fronts when you turn. It'll probably be OK depending on how low you ride. -------------------- "It's ok to be naked girl... I'm an artist!"
Mar 23, 2007 - 2:41 PM |
QUOTE(supradog1 @ Mar 23, 2007 - 12:01 PM) [snapback]539110[/snapback] QUOTE(jgreening @ Mar 23, 2007 - 9:54 AM) [snapback]539027[/snapback] QUOTE(WannabeGT4 @ Mar 23, 2007 - 9:32 AM) [snapback]539023[/snapback] QUOTE(Bigmeanbulldog55 @ Mar 23, 2007 - 12:32 AM) [snapback]538990[/snapback] That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock. You are wrong. Come on Wannabe, it might stick out a tone if he squeals his tires going around a curve. so will this offset work or not in your opion??? I think it will, acording to the offset chart you can run +28 stock hight and +40 with droped hight, so if you run +30 offset with roled fenders you will be left with 2mm clearence... this is the optimum offset for maximum wheel lip that you can fit on our cars with out rubbing... (ie, only with the wheel and tire specs givin above...) Tirerack sells +35mm 18x8s for our cars so I'm confident that +30mm will fit... maybe without even rolling your fenders. We're talking about a 5mm difference. Not something I'd be too worried about if you're already planning on rolling your fenders. -------------------- Project ST204.5 99.88946% complete... |
Mar 23, 2007 - 3:00 PM |
QUOTE(Kwanza26 @ Mar 23, 2007 - 2:33 PM) [snapback]539143[/snapback] QUOTE(Bigmeanbulldog55 @ Mar 23, 2007 - 6:32 AM) [snapback]538990[/snapback] That is going to stick out a tone. I hope you really mean -30 offset. Our cars are -35 stock. Our stock offset is +35 ish. -35 is is like... WHOA NUTS! The wheels will be sticking several inches out from the fender. QUOTE(supradog1 @ Mar 23, 2007 - 6:01 PM) [snapback]539110[/snapback] so will this offset work or not in your opion??? I think it will, acording to the offset chart you can run +28 stock hight and +40 with droped hight, so if you run +30 offset with roled fenders you will be left with 2mm clearence... this is the optimum offset for maximum wheel lip that you can fit on our cars with out rubbing... (ie, only with the wheel and tire specs givin above...) 18x8 with a 30mm offset is pushing it very very close. I tend to think it'll rub on the fronts when you turn. It'll probably be OK depending on how low you ride. Ok. I will be serious. Turning wont be a problem. The fronts will be perfectly fine. The only issue is whether the rears will scrape when you go over a bump. With rolled fenders, my guess is that you wont have a problem. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 23, 2007 - 3:38 PM |
so what do you think the max offset is for our car when lowerd???
Mar 23, 2007 - 4:34 PM |
QUOTE(supradog1 @ Mar 23, 2007 - 3:38 PM) [snapback]539170[/snapback] so what do you think the max offset is for our car when lowerd??? That question cannot be answered without rim width. it also helps to know what size tire you are going with as well because tire size can effect wheel width. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 25, 2007 - 12:17 PM |
QUOTE(jgreening @ Mar 23, 2007 - 5:34 PM) [snapback]539181[/snapback] QUOTE(supradog1 @ Mar 23, 2007 - 3:38 PM) [snapback]539170[/snapback] so what do you think the max offset is for our car when lowerd??? That question cannot be answered without rim width. it also helps to know what size tire you are going with as well because tire size can effect wheel width. 18x8 + 225/35/18 + 1.75 drop + roled = +?? offset... ( i think +29 offset is as far as you can go!!!) This post has been edited by supradog1: Mar 25, 2007 - 12:20 PM |
Mar 25, 2007 - 12:26 PM |
If you roll your fenders one centimeter you'll be perfectly fine with +30mm on an 18x8. You may not even need to roll your fenders with the size tire you've chosen.
Mar 25, 2007 - 6:56 PM |
Wannabe is correct. The wheels will look very flush. I think you will be very happy with the look in that size. The only thing that gives me pause is the 35% sidewall which will significantly increase the harshness of your ride on roads that are less than ideal.
Mar 25, 2007 - 10:39 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
stock suspension cept sway bar - 35mm offset 18x8 no probs - tis on a coupe so i dunno how much hatchs differ in this department - they deff look amazing flush against the car like that, makes it look like a million bucks in my mind
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Mar 25, 2007 - 11:10 PM |
QUOTE(jgreening @ Mar 25, 2007 - 7:56 PM) [snapback]539718[/snapback] Wannabe is correct. The wheels will look very flush. I think you will be very happy with the look in that size. The only thing that gives me pause is the 35% sidewall which will significantly increase the harshness of your ride on roads that are less than ideal. i know it was a bad choice on tire size... at that time i was thinking it would rubb so i went a little thin on the side wall, but onice i have the car on the road i can do some "real world" testing and see what works then... also the roads here in FL around my city are near perfecit... |
Lo-Fi Version | Time is now: January 10th, 2025 - 3:11 AM |
