> Help on motor mounts (pic added), Rear motor mount changed!!!!
post Mar 25, 2007 - 11:54 PM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
anyone know how to change the rear motor mount??? i need to change it ASAP!!!!!
This post has been edited by Rockford: Apr 5, 2007 - 10:18 PM
Celica ST202
post Mar 26, 2007 - 5:55 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
QUOTE(Rockford @ Mar 26, 2007 - 4:54 AM) [snapback]539818[/snapback]
Raise front of car on jackstands or ramps. Support engine mount crossmember with jackstand. remove dust covers at rear of crossmember, remove attaching bolts (2 nuts and 1 bolt), at this point only the forward crossmember bolts and forward engine mount bolts are supporting the crossmember, remove thru bolt on rear mount( I had to use a long extension from the driver side of the car). May have to remove rear mount bracket (attached to engine block)and exhaust pipe support bracket for mount to be removed. use floor jack to help with realignment of thru bolt when installing new mount.
This post has been edited by 56willysnut: Mar 26, 2007 - 5:56 AM
post Mar 26, 2007 - 10:32 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
I do something similar, just unbolt and lower the crossmember and then you can easily remove the mount.
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 26, 2007 - 12:25 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
same here
post Mar 30, 2007 - 3:37 PM
Rockford
Joined Dec 22, '06
any pic pls!!!!
Celica ST202
post Apr 5, 2007 - 10:19 PM
Rockford
Joined Dec 22, '06
take a look of my old rear motor mount!!!!
age..... 10 years....
Celica ST202
post Apr 5, 2007 - 10:52 PM
^^^ hahaha that is awesome !!!
that thing is destroyed !! was it like that or did you do that to it trying to get it out ?
post Apr 5, 2007 - 10:58 PM
Rockford
Joined Dec 22, '06
QUOTE(Batman722 @ Apr 5, 2007 - 11:52 PM) [snapback]543777[/snapback]
when my friend and I began to dismantle the bolt that holds the center of the mount we saw that trene no exist any of urethane..... and when the mount came out.... we all get impressed seeing that!!! laugh.gif laugh.gif
Celica ST202
Lo-Fi Version Time is now: February 21st, 2025 - 3:23 PM
