Normal operating temperature problem, whats the normal operating temperature? |
Mar 26, 2007 - 10:21 PM |
Enthusiast Joined Jul 27, '06 From Minnesota Currently Offline Reputation: 0 (0%) |
hey guys, my gauges have been known to be misleading, like my fuel gauge for half a year been about a centimeter off, so when i was full on gas, it would be at the second bar, and when it would be empty it would be below the E bar, ect... (it eventually fixed itself????)so im wondering what the normal temperature is for a Celica ST, MY teacher at school has a Check Engine thing, which tells all the details on the engine, like rpm idle speed misfires, ect, and my temperature read.... crap i forgot, i think it was 81degrees Celsius. is that normal? well, whatever it is i cant seem to fix it. its about 3/4s way to the top, and has never gone above, or below,. i've changed the thermostat, the coolant where u can check it, is kinda brownish? im not sure if its the Toyota coolant, or it has a gasket leak ? but in the radiator its still green so i dont know, any feedback will help! thanks...
This post has been edited by mathshop: Mar 26, 2007 - 10:23 PM |
Mar 28, 2007 - 2:29 PM |
Someone probably mixed green and Toyota red.
That will create a brownish color. While you can mix most coolants [it won't create any type of crazy chemical reaction] it's not the best idea. Partly because of the misleading color it can create. IMO, use Toyota red and distilled [NOT tap] water. Most green coolants have silicates in them. According to Toyota silicates are bad for water pump seals. :shrug: Toyota red doesn't have silicates. However, because of this it's anti corrosion properties don't work very well with hard [lots of minerals] water. Distilled water is pure H2O. 81* C is 178* F. Which is totally fine. The gauges in your panel aren't always 100% accurate.... -------------------- |
Lo-Fi Version | Time is now: November 28th, 2024 - 7:57 AM |
