popping noise, i hear something |
Mar 27, 2007 - 5:10 PM |
Enthusiast Joined Mar 7, '07 From dallas texas Currently Offline Reputation: 0 (0%) |
ok its not a real problem but now its getting annoying! every time i shift gears i hear like this popping noise coming from my exhaust even at low rpms. Sometimes i doesnt happen, keep in mind i have 2.25 ehaust piping and a aftermarket catback could it be backpressure problems and will it harm my hp? ur advice is apreciated-thnx
-------------------- DRIVE UP..........
ACCEPT THE CHALLENGE......... DESTROY YOUR OPPONENT......... |
Mar 27, 2007 - 8:07 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
You can try checking your timing if it's to factory spec. If it is, then it could be just your exhaust setup. Well, I got the popping also but performance hasn't gotten bad or anything. I'm pretty sure it's normal with an aftermarket exhaust.
This post has been edited by netrata: Mar 27, 2007 - 8:25 PM -------------------- |
Mar 30, 2007 - 3:04 PM |
Enthusiast Joined Mar 11, '07 From Brisane, QLD Australia Currently Offline Reputation: 0 (0%) |
yeah i got popping noise too but i have a catless exhaust. sometimes its really loud like backfire.
my car is running fine so i think its normal. |
Mar 30, 2007 - 11:41 PM |
QUOTE(Bling-bling @ Mar 30, 2007 - 8:04 PM) [snapback]541518[/snapback] yeah i got popping noise too but i have a catless exhaust. sometimes its really loud like backfire. my car is running fine so i think its normal. thnx for the info plus how did u go catless? do u have a header installed? -------------------- DRIVE UP..........
Mar 31, 2007 - 5:43 PM |
Most likely a backfire.
Unburned fuel getting combusted in the exhaust. If that's the case, either you're not getting full combustion in the chamber or you are running a tad bit rich. -------------------- |
Apr 2, 2007 - 9:33 AM |
Nah my car just has a stock header. i think to go catless u just replace the catalytic converter with a piece of exhaust pipe.
Apr 2, 2007 - 9:36 AM |
QUOTE Nah my car just has a stock header. i think to go catless u just replace the catalytic converter with a piece of exhaust pipe. Then you would still have a cat, because there is one on the exhaust manifold as well as along the piping. I have this happen every once in a while with my exhaust setup, and I have both cats still! The last time was a few months ago, but I remember when I heard the pop from the exhaust, I felt it in the pedals as well. Very strange, but it doesn't bother me. I just love the rumble! This post has been edited by 95CelicaST: Apr 2, 2007 - 9:39 AM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: January 10th, 2025 - 2:50 PM |
