> Seafoamed engine today
post Mar 27, 2007 - 8:38 PM
atif7x7
Joined Feb 20, '07
From Toronto, Canada
WOW ! quite an experience .. i sea foamed the engine today .. car smoked intensely for 10 minutes .. afta that it was smooth as if i juss drove it off the showroom lot ... no more vibrations .. juss the sound of the muffler ..
Also changed tranny fluid to synth and engine oil .. new pcv valve and air filter ...
and i already feel the difference !
next on the list : new rotor cap wires n plugs !
any of u guys seafoam ur engines here ? experiences ?
Looking for parts in the Ontario area .. if any1 can supply me some mods .. pm me .. THX
Looking for: Lowering Springs, Front Lip, JDM Rear Lights, Cold Air Intake
post Mar 27, 2007 - 9:10 PM
celicaST
Joined Jun 23, '05
i did mine at 60k. dont think my engine was dirty enough for it to make much of a difference. ive read lots of positive reviews on the product, good stuff thumbsup.gif
post Mar 27, 2007 - 9:54 PM
99GT
Joined Dec 14, '06
From MN, USA
A lot of car forums I've heard about sea foaming. Good and bad reviews, can you explain more and the process?
post Mar 27, 2007 - 10:05 PM
atif7x7
Joined Feb 20, '07
QUOTE(99GT @ Mar 28, 2007 - 2:54 AM) [snapback]540480[/snapback]
All i did was buy seafoam at Auto Parts shop and then fed it via one of the vaccum tubes into the intake manifold .. this lets the sea foam travel to all four cylinders .. cleans out injectors .. burns carbon deposits etc ...
When u do it make sure its in an open place.. start ur engine .. disconnect one of the vacuum tubes and let it suck the seafoam in (it is a liquid). the car will start smoking heavily in a minute or 2. the directions told me to use 2/3 of the can which i did. I left the car idling for 10 minutes after the process revving it heavily at times in the middle.
I had a 2000 civic before which i did the same on and that forum had a detailed "how to" sticky on it for sea foaming.
I have done it so have many of my buddies and none of us ever had any problems. As long as your motor is not already leaking oil or in a bad shape, I dont see any problems.
If you have never done it and if your motor has high clicks on it, i bet u anythin tht u will see the difference .. Providing everything else is working properly, your idle will become smoother, I have had friends temme that they got increased mileage too, though i have never payed attention to that ..
Thats all the info i can give u. If some1 here has some pics and a detailed sticky on it, it would be great
This post has been edited by atif7x7: Mar 27, 2007 - 10:07 PM
post Mar 27, 2007 - 10:06 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
from what ive heard is that the only "bad" experiences that people have is when the sea foam uncovers future problems that were going to happen anyways...
post Mar 27, 2007 - 10:10 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
you put 1/3 in the crakcase, 1/3 in the gas tank, and 1/3 through a vac line like the PCV
it thins out the oil so you should do it right before you need an oil change, run it for maybe a day or two after doing the seafoam then change the oil. I didn't know that when I did it, I changed the oil before doing it and ran it with the seafom for like a week until my oil light came on kindasad.gif
I <3 Dustin---07/16/06
post Mar 27, 2007 - 11:09 PM
99GT
Joined Dec 14, '06
From MN, USA
Cool, thanks! This is all new info to me haha. I'll try this at 75,000 mark.
post Mar 28, 2007 - 11:26 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I'm at the 130K mark ( I bought it with 82K kindasad.gif ) and I am thinking about running seafoam through next oil change. If all goes well I might try it on my girlfriends car too. Which vac line did you use for this?
**** Photobucket
post Mar 28, 2007 - 1:25 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
the vac line to use , on the 5s is on the left side of the intake manifold , near the front there are 2 of them, cant remember which one exactl;y but just turn the car on and unhook one and attach your own section of hose onto the nozzle on the intake, if its sucking in then you have a good line.
just let the engine slowly suck up about 1/3 to a 1/2 of a can (i use a half wink.gif ) then turn off the engine. thats one this most ppl dont do but it allows for the seafoam to settle and work its magic. then i usually turn it on and rev her up until the smoke settles.
one thing you might want to consider eventually is a spark plug cleaning or change. the seam foam breaks up and burns off so much crap that your sparks get polluted.
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Mar 28, 2007 - 1:27 PM
95CelicaST
Joined Feb 5, '05
and for the 7A? Anybody?
**** Photobucket
post Mar 28, 2007 - 2:53 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(quicknstyle @ Mar 27, 2007 - 10:06 PM) [snapback]540484[/snapback]
Exactly.
I've had very good experiences with it.
However, I personally don't put any in the crankcase.
Using good oil like Mobil 1 will clean it out just fine. More than you might think.
And this is less of a shock than the Seafoam...
post Mar 28, 2007 - 3:35 PM
Mangozac
Joined Mar 13, '07
From Gold Coast, QLD, Australia
I assume it's not a bottle of that gunky foam the ocean makes in bad weather wink.gif
How exactly does it work and how safe is it for the engine? My 5SFE has 215000 on the cock - would it be a worthwhile exercise for her?
Zac
post Mar 28, 2007 - 4:52 PM
yea man that would probably benefit you alot
though with that many miles the chances that it will uncover some leak or such is probably pretty good...
if you go to your local parts store they should have a bottle...
post Mar 29, 2007 - 9:14 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(95CelicaST @ Mar 28, 2007 - 2:27 PM) [snapback]540665[/snapback]
the PCV valve comes right out of the middle of the valve cover. pull the hose off and suck it in through there
post Mar 29, 2007 - 2:04 PM
Slick
Joined Jan 10, '06
From Mozambique, Africa
What about a JDM 3SGE? which hose do i use? I went to our local shops and they have no clue what it is. Can i order this stuff online?
post Mar 29, 2007 - 6:34 PM
alltracman78
Joined Aug 9, '06
From Ma
You can try. :shrug:
http://www.seafoamsales.com/
One other option is to get a good quality fuel injection service done.
Not by going to a quick lube place and having them do the same thing you would [suck cleaner out of a bottle], but actually have a cleaner misted into your engine as it runs, another ran through the fuel line [pump is disabled], and a can put in the gas tank.
This will actually work better than Seafoam [not to knock it, it's great stuff].
The problem is the price.
Where I work it's $150.00....
post Mar 29, 2007 - 8:53 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(Slick @ Mar 29, 2007 - 2:04 PM) [snapback]541066[/snapback]
go to Autozone or advance auto they have it
and here are some pics i took last year (before the 3sgte swap) IPB Image
EDIT: OOPS! im an ass... i just realized you were in africa. If they dont have any in your local shops then maybe somebody here can send you some? just paypal them i guess?
This post has been edited by easternpiro1: Mar 29, 2007 - 8:59 PM
post Mar 31, 2007 - 2:32 PM
Slick
Joined Jan 10, '06
QUOTE(easternpiro1 @ Mar 30, 2007 - 3:53 AM) [snapback]541219[/snapback]
No worries. I'll see if i can order it online. thanks!
post Apr 1, 2007 - 10:49 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(alltracman78 @ Mar 29, 2007 - 3:34 PM) [snapback]541176[/snapback]
I second the fuel injection cleaning. Ask the shop that your going to get it done at what cleaning method that they use. I used a Snap-on Motorvac at school and have noticed a huge difference (on my pickup, 97 Toyota T100). The other cleaner that I know of is BG and thiers doesn't work as good.
This post has been edited by bindertch: Apr 1, 2007 - 10:50 PM
post Apr 4, 2007 - 5:08 PM
alltracman78
Joined Aug 9, '06
From Ma
BG is what we use at work. :shrug:
It works pretty good for us.
What is the actual cleaner you used in the motorvac?
Lo-Fi Version Time is now: November 26th, 2024 - 8:27 PM
