![]() Enthusiast ![]() ![]() Joined Dec 8, '03 From Atlanta from millville nj org. Currently Offline Reputation: 8 (100%) ![]() |
ok i need to know is it just plug and play with cutting a 9006 connector and replacing it with the h1 is it just where u cut the 2 wires and crimp the replacing connector and ur good or do u like match the wires wit the stripe in them and call it good does anybody have pics or like could help me out thanx.
QUOTE(Batman722 @ Mar 28, 2007 - 10:43 PM) [snapback]540879[/snapback] yea i understand that but im goin from a h4 connector to a 9006 i was just wonderin is it just like cut and crimp that is it doesnt matter on what wire is what as long as i connect them that is my ? can i just do that. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(95silvergt @ Mar 28, 2007 - 11:20 PM) [snapback]540885[/snapback] QUOTE(Batman722 @ Mar 28, 2007 - 10:43 PM) [snapback]540879[/snapback] yea i understand that but im goin from a h4 connector to a 9006 i was just wonderin is it just like cut and crimp that is it doesnt matter on what wire is what as long as i connect them that is my ? can i just do that. you're making this more complicated then it is. You're going from a 9006 to an H4 you cut off the two wires coming out of the 9006 harness. You crimp them to the h4 harness. What do you mean what wire? I think i know what you mean and it doesn't matter. -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) ![]() |
dont cut!!!!!!
i just got h4 connectors, pulled the one wire out of it so it was just the 2 that i need so it looks all clean, then the other end of the pig tails i just stripped them and tinned? them (made stiff w/ solder) then just inserted into the existing 9006 harness - this way no cutting and going back to stock is still possible, plus it looks clean =) just get diff diameters of heat shrink and make it all weather proof then, im working on that now actually took 3rd wire out ![]() simple connection no cutting ![]() -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
![]() ![]() ![]() ![]() (2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
lol Jason you and I just took the same pictures of the connector.
the reason i cut the old connector off is because i swapped headlights with someone who had projectors and cut off the orig connector so they needed the 9006 connectors back. The other reason is if i ever decide to sell my car I might want to sell the projectors separately then i can just the h4 connectors off and crimp the old ones back on. i hope you don't mind Jason but i'm adding your pics to my projector thread in the sticky. This post has been edited by ILuvMyCelica95: Mar 29, 2007 - 6:21 PM -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
i have detailed pics on taking off & puttin on the bumper & fenders along with wiring for projectors and the 194 bulb in the side, i think 70 or 80 pics not sure plus about 20 of them on n running, going to eventually do a nice write up so everyone can enjoy them =)
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:16 AM |
