> JDM Engines
post Mar 28, 2007 - 11:12 PM
Kraig
Joined Mar 4, '04
I am looking at a wrecker to buy a new engine something is majorly wrong with my current engine so it needs to be replaced, so i call him and he says he doesnt know what model it is just that it fits a 95 celica, and it is a JDM model, what are the possibilities of engine it can be?
post Mar 28, 2007 - 11:22 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
7afe, 3sge, 3sgte
I will return one day.
post Mar 28, 2007 - 11:37 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
3sfe, 5sfe, 5afe, 4afe...
post Mar 29, 2007 - 12:49 AM
saleeka
Joined Sep 4, '03
From Twin Cities MN
4S-FE also...
post Mar 29, 2007 - 12:52 AM
airswoosh1
Joined Oct 21, '05
From Los Angeles, CA
a lot of importers try to sell a 3sfe as a replacement for the 5sfe
'94 Tercel
USDM 5EFE * OEM MR-S Rims * Kumho ECSTA ASX 205/50R15 * NST Short Shifter
estabon anti-lift plates * KYB GR2 Shocks & Struts * Eibach Pro Kit * Whiteline Rear Sway Bar
Paseo Sway Bar * Paseo Front Brakes * Momo Shift Knob * Paseo Front Seats
JDM OEM Toyota Altezza Side Markers * Corsa Tailights * Corsa Grille * Corsa Trunk Garnish
http://www.socaltercel.com
post Mar 29, 2007 - 11:09 AM
Negative
Joined Apr 28, '04
From Houston, Texas
5A-FE? WTF? Specs etc. I have never heard of this one.
post Mar 29, 2007 - 11:33 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
from Wiki
A smaller 1.5 L (1498 cc) 5A-F was produced in 1987 and the fuel injected 5A-FE was produced that year and again from 1995 through 1998. Both used a cylinder bore of 78.7 mm (3.1 in) and a stroke of 77 mm (3.0 in). Both had 4 valves per cylinder with DOHC heads and used the narrow 22.3° valve angle.
Output for the carb version was 85 hp (63 kW) at 6000 rpm and 90 ft·lbf (122 N·m) at 3600 rpm. Output for the 1987 FI version was 104 hp (78 kW) at 6000 rpm and 97 ft·lbf (131 N·m) at 4800 rpm. The later one produced 100 hp (75 kW) at 5600 rpm and 102 ft·lbf (138 N·m) @ 4400 rpm.
**** Photobucket
post Mar 30, 2007 - 11:56 PM
Kraig
Joined Mar 4, '04
Is there any way to tell what engine it is by looking at it is there any markings somewhere?
post Mar 31, 2007 - 11:55 AM
Remy
Joined Jan 25, '06
From MN
well whats the numbers you see on the engine ?? The 3sgte's are labeled by the side the others should have numbers like 2000 or 2200 something like that on it. wink.gif
"To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version Time is now: November 29th, 2024 - 5:03 AM
