> what does this oil leak mean?
post Mar 29, 2007 - 11:43 AM
ritch1
Joined Feb 16, '07
Hi
I recently had a leak repaired but now it seems i have another one. 2 drips fall to the grounds, one from directly in the middle on the engine and the other about 3 inches in front of the sump. the dripping stops after a while when the car is off and stationary, what does than mean?
if it helps, the repairs where to replace the rocker gasket, crank shift and drive shaft seals, since then i have had this leak.
anyway, if anyone has any ideas id appreciate the help
ritch
post Mar 29, 2007 - 11:47 AM
ur mech. didn't put stuff back tight/correct
post Mar 29, 2007 - 11:48 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Is your drain plug tightened down all the way? Thats where I would start. Try getting up underneath the car and cleaning everything up - when the leak comes back you will be able to see exactly where it is at.
**** Photobucket
post Mar 29, 2007 - 6:29 PM
alltracman78
Joined Aug 9, '06
From Ma
Exactly
Clean it up and locate where it's coming from.
Are you sure both are oil?
post Mar 29, 2007 - 9:33 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
you can add some leak detector.
post Mar 30, 2007 - 4:14 AM
ritch1
Joined Feb 16, '07
i took it to my garage for a quick look, they said its coming from the sump and it is only a small leak, they also said keep an eye on it and if if it gets worse take it in
so they say i got the choice of leaving it or getting the work done. the drips are annoying but i cant afford another garage bill at the moment so think i will put it off for a while
Lo-Fi Version Time is now: November 26th, 2024 - 2:24 AM
