> gauge light not working, GRRR
post Mar 29, 2007 - 4:02 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
couple days ago i changed my turn signals to be red instead of green last night when i drove it to get some food one of the lights in the dash wouldn't work. it was the one that lights up the right side of the gauges. i took out the gauges again checked the connection and it seemed to be connected just fine. then i tried it again to see if it would work. and it did and so i put it all back in and tried it again to make sure and now it didn't. confused.gif wtf? please someone tell me that this would be an easy fix. i am going to take it apart again tonight but if there are any pointers that would be much appreciatted. thanks guys
post Mar 30, 2007 - 7:00 AM
alltracman78
Joined Aug 9, '06
From Ma
You changed the actual bulb in the cluster?
Or just the rubber/plastic "condom" on it?
It sounds like a bad connection.
post Mar 30, 2007 - 10:12 AM
I had the kind of same problem last night. Except i shorted out the A/C controls while working with them. Right after that i felt smoke. What happened, the circuit board burned one of the little copper roads, i lost the illumination.
Solution: I soldered a bridge with a small wire and soldering paste, to make up the connection. Chek bulbs first, then check if any of the conections are burned,. If in doubt i will have an expert take a look at it.
Hope it helps.
post Mar 30, 2007 - 5:12 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
hey thanks for the help. i went to radio shack and got some new bulbs and i guess that was the problem. the only thing that made me wonder is that it turned back on for a second then back off as if it was a wiring problem. well hopefully that was all that was wrong with it. i
Lo-Fi Version Time is now: February 25th, 2025 - 7:07 PM
