> Breaking up in upper RPMS
post Mar 29, 2007 - 6:53 PM
JaxMadine
Joined Jan 31, '06
My buddys got a 94 with a 3rd gen. Just on saturday it started breaking up @ WOT in the upper rpm range. Any ideas of what could be wrong?
post Mar 29, 2007 - 7:08 PM
alltracman78
Joined Aug 9, '06
From Ma
Misfire?
post Mar 29, 2007 - 8:02 PM
how much boost?
post Mar 29, 2007 - 9:12 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
plug gap maybe
i love being able to blame the plugs or torque conv. on auto cars.
NGK Coppers ftmfw!
post Mar 30, 2007 - 1:46 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
if its the same RPM every time its probably the coil
post Mar 30, 2007 - 11:24 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Did he change out his fuel pump when he did the swap? I've seen this happen on a 2nd gen CS motor.
post Mar 30, 2007 - 11:42 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
ignition or fuel delivery ...
pump, filter, regulator
or coil , plugs , wires
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Mar 30, 2007 - 3:04 PM
JaxMadine
Joined Jan 31, '06
It was the plugs, turns out he had some junk Iridium plugs in it. Suckers were a desert sand orange, its nuts!
post Apr 2, 2007 - 8:14 PM
Consynx
Joined Dec 25, '02
Go Me!
lmfao!
Lo-Fi Version Time is now: February 18th, 2025 - 3:16 PM
