my celica collage what do you think, first collage or anything ive ever tried |
Apr 5, 2007 - 3:23 PM |
Enthusiast Joined Mar 26, '07 From CP 518 Currently Offline Reputation: 0 (0%) |
2nd 1 any better?
Apr 5, 2007 - 3:37 PM |
Enthusiast Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(cel97ica @ Apr 3, 2007 - 6:26 PM) [snapback]542876[/snapback] just finished took like 10 min anybetter??? after i finished i thought about some stuff i could of added maybe ill fix it then put the remade up No offence.. but keep at it Here what i would say 1) too much skew on the upper embelem 2) Very bad job of cutting objects out... The muffler isint round, i see white space under the car and... a square out of the tire ??? Did you do this in paint? If not... spend a bit more time cutting out your object.. use the magnification tool and carefully select your edges. Try using a bit of blending when pasting objects. Good luck -------------------- ----- '94 ST hatch --- Yellow ----- |
Apr 5, 2007 - 3:58 PM |
thanks for the advice i used corel paintshop pro, im just figuring out how to use it so ill keep at it
Lo-Fi Version | Time is now: November 28th, 2024 - 2:25 AM |
