6 Pages V  < 1 2 3 4 > »
> 5SFTE Project, Been running since may...small updates!
post Apr 4, 2007 - 9:33 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
yea, thats the setup im following...ordered the exact same pipes as manny has....because theres no better way to pipe it than that right there!! smile.gif
post Apr 4, 2007 - 9:37 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
QUOTE(Pipo @ Apr 4, 2007 - 12:36 AM) [snapback]542839[/snapback]
QUOTE(jcaron9gt4 @ Apr 3, 2007 - 3:23 AM) [snapback]542569[/snapback]
I bought the intercooler off ebay...its a JDM Sport FMIC Intercooler 28x7x3 with 2.5 intlets
The gauges im not too sure about...i read some mixed reviews, mostly good ones, but some people didnt like them.
I am almost positive that the oil filter has to be moved...You can fit a downpipe on without moving the filter, however, you'll never be able to get the filter off to change your oil....theres just not enough room.
Check this out
btw, is that crush bend piping i see down there? not good
post Apr 4, 2007 - 1:50 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(jcaron9gt4 @ Apr 4, 2007 - 7:37 AM) [snapback]543053[/snapback]
Check this out
Yes. That's a Camry engine bay. There is a motor mount in the way of a normal 3s-gte downpipe. It attaches to the front of the block. The 5s-fte Camry guys (93-up) have to run piping like that - though I have seen many better versions (2.5" mandrel bent following the same route).
I had a 3s-fte in my Camry beforehand and never relocated the oil filter - it can be done with a custom downpipe. Just don't plan on doing an oil change when the motor is hot!
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 4, 2007 - 2:11 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Relocation is not necessary - just save alot of headaches when changing the oil. Although it works well to leave it as the stock setup and if it can be done on an MR2 it can be done on anything. I just can't see adding in extra stuff on something as important as oil.
post Apr 4, 2007 - 6:04 PM
QUOTE(Negative @ Apr 4, 2007 - 3:11 PM) [snapback]543135[/snapback]
i cant see fitting a normal sized oil filter WITH the stock oil cooler in place.
the camry is another story all together, IIRC it dont come equipped with the oil cooler like the celica does.
post Apr 4, 2007 - 6:06 PM
alltracman78
Joined Aug 9, '06
From Ma
Damn dude, it must sit different on the 5S...
BTW, all you with 5SF/GTEs use a 3SGTE filter and not a 5S filter, right?
post Apr 4, 2007 - 9:03 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(alltracman78 @ Apr 4, 2007 - 4:06 PM) [snapback]543207[/snapback]
difference being?
I thought toyota pretty much only has one filter that they use on all their cars.
post Apr 11, 2007 - 1:40 PM
Cisco93lude
Joined May 10, '06
From Somerset
Bump for Justin's 5sfte!! all the parts are purchased. The oil pan is the last item that should arrive by tomorrow. We will be installing most of the parts this weekend. so hopfully we can get this running by next weekend!!! laugh.gif laugh.gif laugh.gif laugh.gif
post Apr 11, 2007 - 4:09 PM
phattyduck
Joined Dec 5, '05
From LA, CA
The FE head is much smaller. It does make everything sit closer to the block...
-Charlie
post Apr 12, 2007 - 12:27 AM
99GT
Joined Dec 14, '06
From MN, USA
Can't wait for more updates... good luck!
post Apr 12, 2007 - 12:33 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(99GT @ Apr 11, 2007 - 10:27 PM) [snapback]545869[/snapback]
x2
post Apr 12, 2007 - 8:57 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
hey guys...we'll have alot of this stuff in this weekend, so ill have lots of pics up by the end of the weekend!!! Then hopefully if everything goes good....BOOOOST by the end of next weekend!!!
post Apr 12, 2007 - 11:56 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
94 Celica gt white (sold)
post Apr 15, 2007 - 5:07 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
Hey guys...not too much went in today due to some pretty bad weather over here, and lack of garage. Looks like its gonna be raining tomorrow too, so i'll have to do what i can....However, some things did go in today, the fuel pump is all set now, and so are the injectors. Here's some pics of what was done today. Hopefully tomorrow so more stuff will get to go in if the weather works with us.
Picture of under my backseat, before the stock fuel pump was pulled.
Picture of my stock pump, after being pulled out
Picture of te new pump, all wired up and ready to go
Hopefully i'll have more updates tomorrow for you guys, but this was all that couyld be done today.
post Apr 15, 2007 - 5:09 PM
6strngs
Joined May 12, '06
From Wilmington, NC
how long did it take just to do the fuel pump and injectors?
post Apr 15, 2007 - 5:22 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
QUOTE(6strngs @ Apr 15, 2007 - 10:09 PM) [snapback]546982[/snapback]
post Apr 15, 2007 - 6:27 PM
rickycillo
Joined Apr 7, '07
From Puerto Rico
nice project,mine its almost done i have all the components to finish it but the guy whos gonna do the work mounting the intercooler told me to wait untill i have the front bumper that i order,because he dont know if it change the dimensions of the new bumper.take a look of some of my pics maybe we can share some ideas
post Apr 15, 2007 - 9:03 PM
nice job so far.
lookin good!
post Apr 15, 2007 - 9:07 PM
Cisco93lude
Joined May 10, '06
From Somerset
Ya todays work could have been done in less but the weather didnt help at all lol and also the back of the block was covered in oil so it was hard to take the fuel rail off.
post Apr 15, 2007 - 9:40 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
QUOTE(Cisco93lude @ Apr 16, 2007 - 2:07 AM) [snapback]547077[/snapback]
yea ...i guess that was my B lol
Lo-Fi Version Time is now: November 27th, 2024 - 10:32 AM
