> Adjusting Headlight Beams
post Apr 3, 2007 - 4:59 PM
twitchh17
Joined May 19, '06
From North NJ
hey hows it going everyone? its been a year since I wanted to change the beam pattern for my headlights so its nice and straight. my left headlight's beam is going downward instead of outward like the right headlight. does anyone know how to adjust the stupid thing? when i went to the 6gc meet @ DWG no one could figure it out or could help me lol help with pics will be appreciated thanks in advance
- allan
post Apr 4, 2007 - 5:53 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(twitchh17 @ Apr 3, 2007 - 4:59 PM) [snapback]542758[/snapback]
- allan
NO ONE KNOWS WWTFF?WTFWTWTFWTWFWTWTWWTFFFFF?!??!!??
post Apr 4, 2007 - 6:52 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
well, i did this today, its easiest if you take them off but, but its possible without it. to make the beam shoot up, an 8mm wratchet will do the job. place on the all metal bolt behind teh headlight. if it is the low beam it is a reach, and is easiest if taken off. if the lowbeam it is easy. it takes a lot of turns. use the motion to turn the bolt like you are tightening it, righty tightri, lefty loosey. i did it and no its perfect, well, nearly. a little more for me. good luck twitch
mike
post Apr 4, 2007 - 8:31 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(mneal2_92788 @ Apr 4, 2007 - 6:52 PM) [snapback]543227[/snapback]
mike
hey thanks for replying mneal can you take a pic of the actual bolt youre talking about? thanks in advance :]
post Apr 5, 2007 - 1:16 PM
mneal2_92788
Joined Nov 7, '06
alright well i will out on up for each headlamp.
driver low
driver high
pass high
pass low
hope i helped, any questions just ask
This post has been edited by mneal2_92788: Apr 5, 2007 - 1:17 PM
post Apr 5, 2007 - 10:46 PM
twitchh17
Joined May 19, '06
From North NJ
wow thanks alot mneal12_92788 that was alotttt of help.. finally someone to give me the answer biggrin.gif
thanks for the pics and stuff too. there should be alot more people like yourself on this forum - real helpful - good stuff ^^
post Apr 6, 2007 - 11:25 AM
mneal2_92788
Joined Nov 7, '06
not a prob, i do what i can to help.
post Apr 30, 2007 - 11:52 PM
LeonStryfe
Joined Mar 28, '06
From Brooklyn, New York
QUOTE(mneal2_92788 @ Apr 6, 2007 - 12:25 PM) [snapback]543969[/snapback]
lol nice that helped me too, my left light is sagging really badly. How does it aim? right -> Tight = Aim higher? and left is aim lower?
post May 1, 2007 - 12:30 AM
QUOTE(LeonStryfe @ May 1, 2007 - 12:52 AM) [snapback]552736[/snapback]
yes. Tighten it to raise the beam higher.
post May 27, 2007 - 11:27 PM
Remy
Joined Jan 25, '06
From MN
hmm...I tried to adjust my low beams today because I noticed they shoot to the ground and doesn't make the road visible enough for me but when adjusting the screws I noticed no difference at all ?? Still points down after adjusting for 30 mins ?? kindasad.gif
"To Protect And To Serve The Wealthy" -POLICE
post May 28, 2007 - 1:42 AM
bman
Joined May 14, '07
From Long Island
remy are you sure your turning the right screw? pull your car up against a wall or garage and with only 30 seconds of turning you should see a difference...
-i've spent alot of time getting the lights where i want them, it takes patience to tell you the truth
94 Celica ST - CAI, CarPuter, many interior mods!
post May 28, 2007 - 10:29 AM
Remy
Joined Jan 25, '06
From MN
I'm sure they're the right ones I've been turning the screws that are pictured above those are the right ones right ??
post May 28, 2007 - 11:57 AM
bman
Joined May 14, '07
From Long Island
yes sir =)
post Jun 4, 2007 - 3:52 PM
twitchh17
Joined May 19, '06
From North NJ
oh yeah does anyone know what kind of screw is the one we turn to lower and raise our lights? i didnt know if u turned to the left it aims lower. i turned mine way too many times and now the screws gone lol. thanks
post Jun 4, 2007 - 10:38 PM
mneal2_92788
Joined Nov 7, '06
it is a phillips screw
post Jun 5, 2007 - 8:26 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(mneal2_92788 @ Jun 4, 2007 - 10:38 PM) [snapback]565017[/snapback]
oh yeah when i DID have the philipps screw in the headlight i kept turning it right and it seemed like it wasnt doing **** lol. is there any reason why its not doing wat its suppose to do?
This post has been edited by twitchh17: Jun 5, 2007 - 8:27 PM
post Jun 5, 2007 - 8:36 PM
mneal2_92788
Joined Nov 7, '06
mine did that once, and i think that once it reaches a point it will not do anything to the beam. idk for sure tho
post Jun 5, 2007 - 8:38 PM
LeonStryfe
Joined Mar 28, '06
QUOTE(twitchh17 @ Jun 5, 2007 - 9:26 PM) [snapback]565338[/snapback]
ifyour doing vertical, look at th ebubble in the beam adjustment. make sure its in the middle |||O||| and ur aim should be fine. if you want it higher move the bubble a little to the left.
post Jun 7, 2007 - 9:48 AM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(LeonStryfe @ Jun 5, 2007 - 8:38 PM) [snapback]565346[/snapback]
sweeeeet just adjusted it this morning. both are in the middle of the ||O|| lol. better be fcking nice now biggrin.gif
post Jun 7, 2007 - 7:46 PM
mneal2_92788
Joined Nov 7, '06
none of my bubbles are in the middle, mine were all over the place when i did that, and i was on level ground when i got them to that point. mine are perfect now tho.
Lo-Fi Version Time is now: November 24th, 2024 - 6:58 AM
