2 Pages V  < 1 2
> Adjusting Headlight Beams
post Jun 7, 2007 - 10:20 PM
twitchh17
Joined May 19, '06
From North NJ
ugh was excietd to get out of work at nite so i could see if the cutoff was straight. the right side is still further out more. after twisting and twisting after i got out of work, i managed to get the left headlight to go farther but it wasnt as bright as it was like i couldnt see sht.. and the right side was still really bright wtffffff is it just my car? lol
oh yeah when it was on leveled ground i got both bubbles to go in the middle but that didnt work wttttttttttttttttttttttttttttffffffffffff lol
This post has been edited by twitchh17: Jun 7, 2007 - 10:21 PM
post Jun 7, 2007 - 10:41 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
just keep messin with it until you get it. i took my car to where there is a ledge about a foot and a half off the ground. parked near it, like 5 feet away. and adjusted my lights right there until they were all at the top of the ledge, the highs just a bit higher than the lows.
post Jun 7, 2007 - 10:57 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(mneal2_92788 @ Jun 7, 2007 - 10:41 PM) [snapback]566270[/snapback]
i mean i got it evened out both headlights but like the further the left headlight goes seems as if it gets less brightness and the right side is always real bright on the ground
post Aug 19, 2007 - 9:02 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
to adjust left and right you use an 8mm screw?? and vertical is a philip?? where is this one located?? and what bubble are you guys talking about
post Apr 25, 2009 - 8:49 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
sorry for bringin it back from the dead, but is it possible to adjust our headlights from right/left? im using 6k hids in stock housings and im throwing light everywere! lmao
Lift Addict!! ^_^
post Apr 26, 2009 - 12:37 AM
azian_advanced
Joined Apr 18, '05
From Calgary
you can adjust from left to right but it doesn't change the fact that you have non-projector lights and will be shooting the light in all directions (regardless of the cutoff beam due to the pattern on the lens).. if you want a perfect cut off, you'll need projectors, but the regular lamps will give you somewhat of a cutoff beam but is more of a gradient dispersion than an off/on type of beam.. kinda hard to explain w/o pics.....
post Apr 26, 2009 - 5:40 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
yeah i figured as much, id love to get projectors, but money and a turbo come first. thumbsup.gif so anyways how do u adjust from left/right, is there another screw besides the up/down one??
Lift Addict!! ^_^
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 17th, 2025 - 1:58 PM
