> cylinder head help!
post Apr 3, 2007 - 5:23 PM
SlickRick
Joined Feb 18, '07
From So Cal
well my head gasket blew and i am putting the head back together and i want 2 know if anyone knows if with the 5s when u put th head back on if u should use new head bolts, and what r the torque specs for the head bolts. Thanks!
Your signature is not allowed on 6GC - Defgeph
post Apr 3, 2007 - 6:14 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Those bolts are torque to yield so you cannot re-use them. Torque to yield means that you torque them to spec and then continue to turn them for a specific degree.
Specs: 36 ft/lbs + 90 degrees
The torque sequence is to start with the center two and then do a cross patern working your way outward.
post Apr 3, 2007 - 7:09 PM
SlickRick
Joined Feb 18, '07
From So Cal
QUOTE(bindertch @ Apr 3, 2007 - 11:14 PM) [snapback]542790[/snapback]
thanks!! thats a huge help! i was just gonna use the old bolts.
Lo-Fi Version Time is now: January 10th, 2025 - 4:21 AM
