2 Pages V  < 1 2
> ct 26, whats the stock psi for a ct26
post Apr 6, 2007 - 6:24 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
This post has been edited by toyotacrazy: Apr 6, 2007 - 6:29 PM
post Apr 6, 2007 - 7:02 PM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(presure2 @ Apr 6, 2007 - 6:11 PM) [snapback]544121[/snapback]
trust me, jeremy will know how the ct-26 actuator works better than you, hes a toyota tech. lol
besides the fact that he has one TATTOOED onto his arm!!
And has put so many CT26s on his alltrac than any one I've known. tongue.gif
Joking aside, the T-VSV is actually a bleed valve.
It bleeds pressure out of the actuator and let the wastegate open at higher psi.
It CANNOT make the car boost lower than the wastegate spring setting.
_Gary
post Apr 6, 2007 - 7:36 PM
alltracman78
Joined Aug 9, '06
From Ma
For a while I was swapping the damn things in my sleep.....
QUOTE(x_itchy_b_x @ Apr 6, 2007 - 5:36 PM) [snapback]544109[/snapback]
QUOTE(toyotacrazy @ Apr 6, 2007 - 5:51 PM) [snapback]544097[/snapback]
QUOTE(alltracman78 @ Apr 6, 2007 - 12:27 PM) [snapback]543991[/snapback]
QUOTE(toyotacrazy @ Apr 5, 2007 - 8:53 PM) [snapback]543703[/snapback]
QUOTE(alltracman78 @ Apr 5, 2007 - 7:57 PM) [snapback]543676[/snapback]
Exactly
And the TVSV can only raise boost from what the WG is set at.
It can't lower it.
sorry,
I havent experimented with my mbc since it doesnt currently work. Ok, so if you use the tvsv and either turn it on or off, manually, then you would stay at 5 psi.
If your WG actuator is set for 8 PSI, you can't go below that, period.
You CAN boost below 8 psi. when the tvis is activated it wont allow the car to boost past 5 psi. This is called SAFE mode. As ive heard it called. When the engine detects knock or cold temperature of the coolant temp.
Your a little confused. its ok though. OK whatever the WG is set to is the lowest possible boost you can run.
when "safe mode" activates it turns off the stock boost controller TVSV and you run W/e the WG spring is.
when "safe mode" isn't on, normal driving conditions it bleeds off air so the actuator opens later, thus upping boost.
i suck at explaining things.
Look, here's the deal.
I don't know EXACTLY what the WG actuator is set to.
It will differer between cars regardless.
Elevation, barometric pressure, humidity, age, wear and tear, heat, air temp, and production differences ALL will effect exactly when it opens. And how fast it opens.
The BGB states stock pressure is from 8 - 11.8 PSI. Most completely stock ones I've see are right around 8.
My 93 Alltrac NEVER ran 5. It was 100% stock [except for a boost gauge], and always topped out at 8 [give or take. Maybe it was 7.5 in actuality, or 8.5].
When I ran the WG vacuum line to the intake manifold it bumped to 10. And stayed there.
All the way to 173xxx miles.
Adding a larger exhaust, a DP, or an intake will raise the actual boost pressure without you using a BC.
So will a better ic. Cold air does this as well.
A buddy of mine has a 90 Alltrac. He put a full Aussie 3" exhaust, a ARC TMIC, and an intake.
He was hitting fuel cut without a BC.
Don't worry exactly what it's supposed to be.
As long as you are 8 - 12 stock you are fine.
12 won't blow your engine either. Assuming everything is good of course.
I had my 92 @ 14 for a long time [some 92/93 ECUs are set to ~14PSI fuel cut]. Part of it on a Supra CT26.
Never had problems. Stock ATA TMIC.
post Apr 6, 2007 - 11:11 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
My wastegate must not be operating correctly. B/C during safe mode Im only hitting 5 psi. After it warms up Im only hitting 8-9. I see what you guys are telling me about the W/G being set at a specific boost and you cant go lower than that.
post Apr 7, 2007 - 5:31 AM
are you swapped with a stock exhaust?
post Apr 8, 2007 - 3:09 PM
malecrod
Joined May 30, '05
From MN
QUOTE(presure2 @ Apr 7, 2007 - 5:31 AM) [snapback]544232[/snapback]
X2
stock exhaust did that to me right after swap, I was not able to boost past 8.5psi. Once replaced, I have been able to boost up to 11psi all stock.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Apr 8, 2007 - 4:15 PM
alltracman78
Joined Aug 9, '06
From Ma
Don't forget, massively retarded timing, such as with a bad knock sensor, will lower boost as well.
post Apr 8, 2007 - 4:30 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(alltracman78 @ Apr 8, 2007 - 4:15 PM) [snapback]544548[/snapback]
I thought the exhaust was slowing me down. I have a turbo xs dump pipe. Then I have about a 2.25" flex pipe. The rest is stock GT. I unbolted everything except the flex pipe. I still only boost between 8-9 max. If I put washers in between my wastegate actuator and the turbo, I can boost all the way to fuel cut (14 PSI). I wonder if my wastegate actuator is worn out. ????? Also, Ive noticed on the few nice 70* F days we had, my tvis monitor leds detected a problem. Then I could only boost to 5 psi. When I cycled the key, it went back to normal.
post Apr 20, 2007 - 1:37 PM
95celgt
Joined Oct 5, '03
From South TX.
hmmmm, so much inconsistency, I just got a MBC because i got tired of 6psi(thats with 3in intake, Full exaust). Just yesterday i finally raised it to 9-10, pulls amazing, but i want to extract the most power possible.
My motor can more than handle it, it was rebuilt, with headwork and an 88MM bore(old was 87MM), the question is how much can I add with the stock engine management(ecu-fuel), and if I want more power what is something good to add?
*I'd like to add that the rotating assembly is fully balanced
This post has been edited by 95celgt: Apr 20, 2007 - 1:38 PM
post Apr 20, 2007 - 1:59 PM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(95celgt @ Apr 20, 2007 - 1:37 PM) [snapback]548854[/snapback]
Manny, Jeremy and I probably have more than 20 years combined experience with CT26 and 3sgte.
Stock CT26 wastegate setting is 7 psi and with right condition and T-VSV fully functional, it will reach 10-11 psi without a boost controller.
If you don't believe that, here is what Toyota manual says
and my stock boost gauge reads 10 psi on a 92*F day
http://www.youtube.com/watch?v=REoG0k_LVjs
You won't go very far with stock turbo and ECU.
Boosting more than 15 psi on a stock CT26 is pushing the limit.
You should consider a bigger/better turbo and other support mods (fuel, intercooling, exhaust, etc..)
Depending on your goal, there are different routes to do this.
300 whp or less, CT27/CT20B, reflashed ECU, 550cc inj, etc...
300-400 whp, TD06, T3/T4, SB kit, stand alone EMS, etc..
This post has been edited by Gary: Apr 20, 2007 - 2:01 PM
_Gary
post Apr 22, 2007 - 11:01 AM
Alan
Joined Jan 23, '05
From Malta
Mine is 10psi stock not boosted, this is because of the bigger free flow exhaust and TVSV removal. 10 PSI is the MAX I got and the reding was on the ECU not boost gauge so it is presice, I couldnt get more pressure 10psi was MAX (stock) hehe
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 23rd, 2025 - 2:38 AM
