Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) ![]() |
Ill take it! PM me. Thanks
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) ![]() |
Don't forget, it depends on what TYPE of MBC he got. There are ball and spring type and bleed type.
If it is a ball and spring, you install it between the boost port on the turbo and the wastegate actuator. You also have to block off the second port on the wastegate actuator and the line that goes to the TVSV. If it is a bleed type, you can install it pretty much in place of the stock TVSV. You may need restrictors and other stuff to get this to work. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
QUOTE(phattyduck @ Apr 5, 2007 - 2:32 PM) [snapback]543537[/snapback] Don't forget, it depends on what TYPE of MBC he got. There are ball and spring type and bleed type. If it is a ball and spring, you install it between the boost port on the turbo and the wastegate actuator. You also have to block off the second port on the wastegate actuator and the line that goes to the TVSV. If it is a bleed type, you can install it pretty much in place of the stock TVSV. You may need restrictors and other stuff to get this to work. -Charlie I got the one with the diaphram. I took it apart and everything seems to be ok. Maybe I just need to place it inline on the other side of the wastegate actuator.???? What restrictors are you referring to? Heres what I bought and am having issues with ebay Heres how I hooked it up at the actuator My Webpage |
QUOTE(toyotacrazy @ Apr 5, 2007 - 5:36 PM) [snapback]543668[/snapback] I got the one with the diaphram. I took it apart and everything seems to be ok. Maybe I just need to place it inline on the other side of the wastegate actuator.???? Well, if you got the one in the eBay link, you have a ball and spring type. Make sure you have it hooked up the right way (like, try flipping it around). It should only hook up right between the boost port on the turbo and the wastegate with everything else blocked off (just like what everyone else has said on the thread so far).What restrictors are you referring to? Heres what I bought and am having issues with ebay Heres how I hooked it up at the actuator My Webpage When I first looked at the thread, the picture did not show up. -Charlie -------------------- 2003 Subaru WRX Wagon
when I took the mbc apart there was a spring and a diaphram. I hooked it up every way except on the side of the wastegate line that wraps around the intake manifold. I think thats what I need to try next. It may need to take place of the factory switching valve.
QUOTE(phattyduck @ Apr 6, 2007 - 2:15 AM) [snapback]543858[/snapback] QUOTE(toyotacrazy @ Apr 5, 2007 - 5:36 PM) [snapback]543668[/snapback] I got the one with the diaphram. I took it apart and everything seems to be ok. Maybe I just need to place it inline on the other side of the wastegate actuator.???? Well, if you got the one in the eBay link, you have a ball and spring type. Make sure you have it hooked up the right way (like, try flipping it around). It should only hook up right between the boost port on the turbo and the wastegate with everything else blocked off (just like what everyone else has said on the thread so far).What restrictors are you referring to? Heres what I bought and am having issues with ebay Heres how I hooked it up at the actuator My Webpage When I first looked at the thread, the picture did not show up. -Charlie This one does not use a ball to regulate boost, but instead, it uses a Acetal/Nitrile Diaphragm. The Turbonetics boost controller uses an advanced mechanism to regulate boost, which uses dual springs to minimize boost spikes. So I need to hook this inline between the vsv and the wastegate actuator instead of on the other side. I dont know why this would make a difference though. This post has been edited by toyotacrazy: Apr 6, 2007 - 5:14 PM |
I have my car back to a stock setup. I know that my stock exhaust is restricting the turbo. So I unbolted the exhaust at the end of the flex pipe. I am boosting 8-9 psi. Safe mode (when its cold) is 5 psi. So there is something wrong with my car? Im pretty sure my gauge is accurate, because when I had washers between the wastegate and the turbo housing, to increase boost pressure by tricking the wastegate, I unhooked my exhaust and I hit fuel cut at 14 psi. Now I took the washers out and its back to stock setup, Im only boosting 8-9 psi. Whats wrong with my car????? I just want to boost 10-12 psi.
This post has been edited by toyotacrazy: Apr 6, 2007 - 6:30 PM |
QUOTE(toyotacrazy @ Apr 6, 2007 - 3:12 PM) [snapback]544100[/snapback] This one does not use a ball to regulate boost, but instead, it uses a Acetal/Nitrile Diaphragm. The Turbonetics boost controller uses an advanced mechanism to regulate boost, which uses dual springs to minimize boost spikes. I called is a "ball and spring type" exactly for that reason. It doesn't matter the exact method of holding back boost (ball and spring or diaphram or lawn gnome), it is that "type". When a certain amount of pressure differential exists between the input and output, it lets air through. Simple, effective, reliable. The idea is that the wastegate still 'sees' the stock pressure that would open the wastegate, but the turbo is at a higher boost.So I need to hook this inline between the vsv and the wastegate actuator instead of on the other side. I dont know why this would make a difference though. You need to completely remove the TVSV from the system. Block off the second port on the wastegate actuator. Block off the pipe that goes back to the TVSV. Put the boost controller between the outlet of the turbo and the first port on the wastegate actuator. This is exactly what has been said on the thread multiple times already. -Charlie -------------------- 2003 Subaru WRX Wagon
QUOTE(toyotacrazy @ Apr 6, 2007 - 4:29 PM) [snapback]544129[/snapback] I have my car back to a stock setup. I know that my stock exhaust is restricting the turbo. So I unbolted the exhaust at the end of the flex pipe. I am boosting 8-9 psi. Safe mode (when its cold) is 5 psi. So there is something wrong with my car? -Charlie -------------------- 2003 Subaru WRX Wagon
QUOTE(phattyduck @ Apr 6, 2007 - 7:00 PM) [snapback]544137[/snapback] QUOTE(toyotacrazy @ Apr 6, 2007 - 3:12 PM) [snapback]544100[/snapback] This one does not use a ball to regulate boost, but instead, it uses a Acetal/Nitrile Diaphragm. The Turbonetics boost controller uses an advanced mechanism to regulate boost, which uses dual springs to minimize boost spikes. I called is a "ball and spring type" exactly for that reason. It doesn't matter the exact method of holding back boost (ball and spring or diaphram or lawn gnome), it is that "type". When a certain amount of pressure differential exists between the input and output, it lets air through. Simple, effective, reliable. The idea is that the wastegate still 'sees' the stock pressure that would open the wastegate, but the turbo is at a higher boost.So I need to hook this inline between the vsv and the wastegate actuator instead of on the other side. I dont know why this would make a difference though. You need to completely remove the TVSV from the system. Block off the second port on the wastegate actuator. Block off the pipe that goes back to the TVSV. Put the boost controller between the outlet of the turbo and the first port on the wastegate actuator. This is exactly what has been said on the thread multiple times already. -Charlie I hooked my mbc up exactly as described by brianfoster and several others. It still doesnt work. I ran a hose from the compressor to the mbc, then from the mbc to the actuator. I then plugged off the second port on the WG actuator. Then I plugged off the other tube that goes under the distributor to the vsv. I then unplugged the vsv for the tvis. My car still wouldnt boost past 4 psi. ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(toyotacrazy @ Apr 6, 2007 - 11:06 PM) [snapback]544183[/snapback] I hooked my mbc up exactly as described by brianfoster and several others. It still doesnt work. I ran a hose from the compressor to the mbc, then from the mbc to the actuator. I then plugged off the second port on the WG actuator. Then I plugged off the other tube that goes under the distributor to the vsv. I then unplugged the vsv for the tvis. My car still wouldnt boost past 4 psi. ![]() Why did you unplug the TVIS? It has nothing to do with installing a boost controller. Don't touch it. Try that and if it still doesn't work, remove the boost controller and test it outside the car. -------------------- _Gary
QUOTE(Gary @ Apr 7, 2007 - 4:45 AM) [snapback]544228[/snapback] QUOTE(toyotacrazy @ Apr 6, 2007 - 11:06 PM) [snapback]544183[/snapback] I hooked my mbc up exactly as described by brianfoster and several others. It still doesnt work. I ran a hose from the compressor to the mbc, then from the mbc to the actuator. I then plugged off the second port on the WG actuator. Then I plugged off the other tube that goes under the distributor to the vsv. I then unplugged the vsv for the tvis. My car still wouldnt boost past 4 psi. ![]() Why did you unplug the TVIS? It has nothing to do with installing a boost controller. Don't touch it. Try that and if it still doesn't work, remove the boost controller and test it outside the car. I tried everything. I unplugged the tvis, I plugged it in, I reversed the mbc. Nothing worked. 4 PSI. No matter what. |
I don't get it. Why don't you just test the MBC outside the car?
It eliminates all the guess work, trial and error, etc ... ![]() -------------------- _Gary
Lo-Fi Version | Time is now: February 21st, 2025 - 8:50 AM |
