Enthusiast Joined Jun 30, '03 From East Coast Currently Offline Reputation: 0 (0%) ![]() |
Ever since i got my car my trunk light has not worked... I have tried replacing it and still no luck..every other light in my car works so what could the possible problem be?? Thanks
![]() Enthusiast ![]() ![]() ![]() Joined Oct 31, '02 From Boise, ID Currently Offline Reputation: 2 (100%) ![]() |
Probably a bad connection somewhere. I could get you the wiring diagrams if you want, but you'd have to be an electrician to use it all. I'd check all the connections around the housing, and if that don't help, I'd almost suggest taking it to your dealer.
-------------------- ![]() psalm 69 |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) ![]() |
i have the same problem,
first, make sure the trunks open second, make sure the switch is in the right direction third, make sure the lightbulb isnt burnt out/broken fourth, check the fuse fifth(where my problem lies) just hit the thing a few times with your fist and it usually turns on. -------------------- i am awesome
Enthusiast ![]() Joined Nov 13, '02 From Bangor, Me/ Huntsville, Alabama Currently Offline Reputation: 0 (0%) ![]() |
If you guys pin point the issue, I have one out of my car that I wrecked that works
Enthusiast ![]() ![]() Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) ![]() |
I just fixed mine last night. The wiring connector for it is a pice of crap. Take the panel off, or loosen it enough to stick your hand behind it. Once back there you need to release the clips that hold the light housing in(having it out of the panel will make it easier). Once you've done that you will should find that the wiring connector is not there,if the connector is not on there reach your hand behind the panel and find it(it will be hanging). plug the connector up and test to see if it works. You may need to put some electrical tape over the connector to hold it in place better. The connector doesn't hold well. On my car somebody had a sytem and the vibration knocked that connector off although i could see how the thing could just fall off from natural vibration. If after you get everything put back together and it still doesn't work then you can cuss me all you like
Lo-Fi Version | Time is now: February 25th, 2025 - 2:49 PM |
