engine losing coolant, oh snap! |
Apr 6, 2007 - 2:45 PM |
Enthusiast Joined Dec 26, '05 From So Cal Currently Offline Reputation: 1 (100%) |
Hey guys, my car has been losing coolant steadily for a few weeks now. There are no visible leaks, so it seems that I have a leaky head gasket. What do you guys think? can you recommend any of those radiator and block leak stop remedies from the auto parts store? I'd like to know what I should do about this, apart from telling people I have a "custom water injection".
This post has been edited by celicamike: Apr 6, 2007 - 2:49 PM |
Apr 6, 2007 - 2:55 PM |
Don't assume it's a HG and act accordingly.
Verify and THEN act..... Don't use any of the stopleak stuff unless it's a temp fix. And once you fix, get a GOOD [not Prestone from Walmart] coolant flush to get all the crap out. Hit up autocrap and see if they have coolant pressure testers to rent for free. If so, rent one and use it. -------------------- |
Apr 9, 2007 - 2:49 PM |
OK, i put some alumaseal in with the coolant and now everything seems fine. Is there anything else I should do? can I just leave it the way it is now?
Apr 9, 2007 - 2:54 PM |
sorry, double post.
This post has been edited by celicamike: Apr 9, 2007 - 2:57 PM |
Apr 11, 2007 - 8:25 AM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
QUOTE(alltracman78 @ Apr 6, 2007 - 2:55 PM) [snapback]544069[/snapback] Don't use any of the stopleak stuff unless it's a temp fix. ^^^^^^^ Werd This post has been edited by Gary: Apr 11, 2007 - 8:25 AM -------------------- _Gary
Apr 14, 2007 - 7:09 PM |
Enthusiast Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
You should be able to see where the coolant leaks out if it is an external leak - it goes pink-white (if you're using the Toyota Forlife red coolant) or looks like a brown surface rust (if you're using green coolant).
If it's a headgasket you will get some vapours and your engine oil will have a layer of sludge on top of it, it's hard to explain but you'll see it if you have it. Conversely you will have a milky layer of oil in your coolant when you open the radiator cap. -------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
Apr 14, 2007 - 7:10 PM |
Enthusiast Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
You better get that fixed soon or that stop leak is going to clog water jackets and whatnot in your engine...
Lo-Fi Version | Time is now: December 4th, 2024 - 7:35 PM |
