Staggered wheel setups...can we run em??? |
Apr 7, 2007 - 11:46 PM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
I've seen a couple 7th gen celis running staggered wheel setups and was curious what are the pros and cons of using that setup...i think it looks pretty sweet and i think it will look awesome on our 6th gens.
Apr 8, 2007 - 2:42 AM |
the only pro to the set up is: it looks good.
the cons: inable to properly rotate tires. increase understeer. |
Apr 8, 2007 - 4:44 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
If you use the same size tire all around, you can still rotate them. Just makes it more work for tire techs because they have to dismount tires, rotate tires (not wheels), and balance.
Apr 8, 2007 - 4:51 PM |
CAUTION !!
NEWBIE question ! what are Staggered wheels ? -------------------- |
Apr 8, 2007 - 5:05 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
QUOTE(Culpable04 @ Apr 8, 2007 - 2:51 PM) [snapback]544553[/snapback] CAUTION !! NEWBIE question ! what are Staggered wheels ? A staggered set up is basically when you have larger or wider wheels in the back than in the front. A staggered set up would be like 18x8.5 in the front and 18x9.5 in the back. The new Lexus IS350 comes with a staggered set up . -------------------- |
Apr 8, 2007 - 5:19 PM |
QUOTE(MaskedMan @ Apr 8, 2007 - 5:05 PM) [snapback]544559[/snapback] QUOTE(Culpable04 @ Apr 8, 2007 - 2:51 PM) [snapback]544553[/snapback] CAUTION !! NEWBIE question ! what are Staggered wheels ? A staggered set up is basically when you have larger or wider wheels in the back than in the front. A staggered set up would be like 18x8.5 in the front and 18x9.5 in the back. The new Lexus IS350 comes with a staggered set up . ahhhhhhhhh ok. thanks -------------------- |
Apr 8, 2007 - 6:02 PM |
QUOTE(Culpable04 @ Apr 8, 2007 - 5:19 PM) [snapback]544560[/snapback] QUOTE(MaskedMan @ Apr 8, 2007 - 5:05 PM) [snapback]544559[/snapback] QUOTE(Culpable04 @ Apr 8, 2007 - 2:51 PM) [snapback]544553[/snapback] CAUTION !! NEWBIE question ! what are Staggered wheels ? A staggered set up is basically when you have larger or wider wheels in the back than in the front. A staggered set up would be like 18x8.5 in the front and 18x9.5 in the back. The new Lexus IS350 comes with a staggered set up . ahhhhhhhhh ok. thanks If I remember correctly someone is building a car on here with a staggered set of wheels. http://www.6gc.net/forums/index.php?showtopic=45285 -------------------- |
Apr 12, 2007 - 10:16 AM |
Enthusiast Joined Nov 29, '06 From South Florida Currently Offline Reputation: 0 (0%) |
i run 18x7.5 and 18x9.5 without much issue....u can feel the undertseer somewhat but unless you track your car, its no major issue
btw the look is bad-asssssss |
Lo-Fi Version | Time is now: December 11th, 2024 - 6:22 PM |
