Enthusiast ![]() ![]() ![]() Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) ![]() |
impact drills are the bombdiggity. That'll get the job done. The most important thing about impact wrenches/drills is that they do not overtorque so it doesnt twist the heads of screws off (I used one 5-6 days a week, 8 hours a day at work for 2 summers and it NEVER overtorqued screws, given it was a DeWalt but that doesn't really matter they are all built relatively the same.) Good luck with your project!
Enthusiast ![]() ![]() ![]() Joined Jun 5, '06 From Hayward,CA Currently Offline Reputation: 4 (100%) ![]() |
its a 12 volt
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) ![]() |
Almost any piece of crap drill, will drill though a panel. The sheetmetal
on our cars is super thin. My cordless cost 19.99 at harbor frieght and it had no problems drilling 6 holes 3/32 dia thu fiberglass and panel, with the same crappy bit the drill came with. I work at a machine shop so I could use our shops dewalt and cobalt or even carbide bits, there is simply no need. A good sharp high speed steel bit and a cordless that is turning over 500 rpm will do the job just fine. The more rpms the better untin you get up to 3000 or so then you start burning bits at a rapid rate. I use 3000 as an example for a small diameter bit, a larger bit burns up at lower rpms. 75 sfpm(surface feet per minute) is a safe surface speed for mild steel X 4 (pie rounded)= 300 300 / diameter of bit in my case .093" = 3225. 3200 is the highest rpm you should turn otherwise you will burn up bits all day long, a larger drill would be slower than that. The formula is the same just divide 300 by the dia bit you are using. Different materials run different sfpm. This formula is for mild steel, aluminum would be considerably faster, and stuff like stainless or titainium would be slower. -------------------- JDM guy made me do it.
hmm. i dont know, cuz liek the front and rear bumper arent metal so i can drill through it with ease, but the quarter panel im trying to drill through is tough. the drill just keeps spinning and spinning and not getting anywehre.
QUOTE(daazndood @ Apr 12, 2007 - 4:08 AM) [snapback]545902[/snapback] hmm. i dont know, cuz liek the front and rear bumper arent metal so i can drill through it with ease, but the quarter panel im trying to drill through is tough. the drill just keeps spinning and spinning and not getting anywehre. ill say it again, maybe you didnt read it last time BITS ARE CONSUMABLE ITEMS YOU NEED TO REPLACE THEM WHEN THEY GET WORN. GO BUY A NEW BIT. the metal panels on our cars are not titanium...lmao, theyre very thin sheet metal. -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
i just imagined him drilling thru the panel with a screwdriver bit.
![]() i hope you get it one day! |
hrmmm....
have you tried using astroglyde? |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 8, '04 From Durham, NC Currently Offline Reputation: 6 (100%) ![]() |
lol
Lo-Fi Version | Time is now: April 22nd, 2025 - 4:16 PM |
