![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) ![]() |
Im replacing the studs on one of my cars (old ones got bent). How do I get the new to "thread" back into the hub? Ive heard of throwing a lug on the end and tightening it down, and that would pull the stud in from behind. When I tried that the stud just spun around (nothing holding it from behind). I tried to give it a bit of "grab" by hammering it in a bit, but it just popped out and spun around. There isnt enough room to hammer it in all the way from the back, because there is a metal shield that sits behind the hub.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
No.
If you remove the hub you will need to replace your wheel bearing. Are you trying with a ratchet? That is probably why they are spinning. Usually a impact gun is used. However, if you can get the splines on the stud to seat in the hub, you should be able to tighten it with a ratchet. -------------------- ![]() |
read this
http://www.6gc.net/forums/index.php?showtopic=43974 and http://homepage.ntlworld.com/r1biker/205brakesonst185.html -------------------- |
Lo-Fi Version | Time is now: February 23rd, 2025 - 6:14 PM |
