> warped discs
post Apr 9, 2007 - 4:43 PM
modcelica
Joined Feb 13, '07
From ireland
does any body know what causes front brake discs to warp . i have changed the discs and pads three times and they only seem to last about one month and then gradually start to warp again
This post has been edited by modcelica: Apr 9, 2007 - 4:44 PM
post Apr 9, 2007 - 5:19 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
improper brake in or just a lot of hard braking
-Brian
post Apr 9, 2007 - 6:35 PM
Hanyo
Joined Aug 16, '03
From Bay area
is it just one side that is warping?
it can be you have a frozen caliper that is constantly rubbing your disk.
post Apr 9, 2007 - 6:48 PM
alltracman78
Joined Aug 9, '06
From Ma
Heat causes them to warp.
While you can have only 1 side warp, it's very unlikely.
More commonly the whole disc warps.
Lower quality steel/thinner rotors will warp easier than OEM ones.
Not to say you can't get aftermarket rotors that are good quality.
Also, if you drive the car hard [lots of hard braking], and park it before the rotors have had a chance to cool, the part of the rotor that is covered by the pad will be more likely to warp.
post Apr 12, 2007 - 11:53 AM
Negative
Joined Apr 28, '04
From Houston, Texas
I think he meant one side of the car not one side of the rotor.
Lo-Fi Version Time is now: December 2nd, 2024 - 7:44 PM
