Jumpy back tire. |
Jumpy back tire. |
Apr 10, 2007 - 6:45 AM |
I recently bought 2 new front tires, and left the ones in the back. All 4 were balanced. But 1 day after i hit a curve with my real right wheel. The rim got scratched. Its been jumpy ever since. I had them rebalanced maybe thinking it was the rim, however it is till jumpy. My question is how do i know its not the suspension that i messed up.
Should i take the car for a 4 wheel alignemnt, and if its something that the real wheel has to be fixed, can anybody do this, and how much should i expect on charges.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 10, 2007 - 7:47 AM |
Enthusiast Joined Jan 16, '06 From Kentucky Currently Offline Reputation: 5 (100%) |
Dude, you prolly bent and warped the bejesus out of your rim.
This post has been edited by 6th_celi_vert: Apr 10, 2007 - 7:47 AM -------------------- Cuz Thats How Us Country Boyz Roll Growing up racing motocross, i learned one thing..."Always wear clean underwear, you never know when the Paramedics are gonna have to cut your pants off of you" |
Apr 10, 2007 - 9:30 AM |
sounds like a bent rim. You'll need to buy a new one.
Apr 10, 2007 - 10:23 AM |
did ya check ur muffler bearings?
Apr 10, 2007 - 4:25 PM |
but if its warped, wouldnt they tell me on the balancing? what are muffler bearings....
Apr 10, 2007 - 11:29 PM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Apr 11, 2007 - 12:34 AM |
they dont balance rotors, look for grooves on the face of the rotor, check your suspension arms too and make sure one isnt bent
Apr 11, 2007 - 8:49 PM |
Enthusiast Joined Nov 10, '06 From Cleveland Currently Offline Reputation: 0 (0%) |
QUOTE but if its warped, wouldnt they tell me on the balancing? They might, but not necessarily. You can still balance a rim that is bent. It is also possible that the tire was damaged; either one can cause the symptoms you describe. Rotate the tires and see if the problem moves to the front. It is most likely not related to the alignment, and I would not suspect the brake discs if it happened after you hit a curb.
Apr 11, 2007 - 8:54 PM |
QUOTE(njccmd2002 @ Apr 10, 2007 - 5:25 PM) [snapback]545320[/snapback] what are muffler bearings.... i rate this thread 5 stars! real answer is you very well could have bent your rim (its not hard) or you got a hub/control arm issue This post has been edited by playr158: Apr 11, 2007 - 8:55 PM |
Apr 11, 2007 - 10:08 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
haha, love the sarcasm, i bent one of my wheels a while ago, sucks, if they dont charge you an arm n leg for alignment, i highly reccomend it every now n then, i check mine monthly and every other month or so tweak it a lil, have ALOT of potholes around here n sometimes ya just can avoid em
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Lo-Fi Version | Time is now: December 4th, 2024 - 3:16 PM |
