> Help with EPC Installation... Please.
post Apr 13, 2007 - 2:15 AM
99GT
Joined Dec 14, '06
From MN, USA
So this is the rules...
Toyota EPC Installation
1 - Copy the contents of disks 1-4 into a temporary directory on your
hard disk. eg. C:\EPCTEMP
EPC SETUP PROGRAM
2 - Run SETUP.EXE
3 - INSTALLATION STEP 1/3
Install the PROGRAM and DATA files onto the same drive
4 - INSTALLATION STEP 2/3
From the drop-down menu, select your CD-ROM drive
5 - INSTALLATION STEP 3/3
Answer NO, to the question about Client/Server operation
EPC PROGRAM SETUP
7 - Run the EPC program, the icon can be found on the START MENU
8 - From the MAIN MENU select CD SETUP
9 - From the CD SETUP MENU select CD SETUP
10 - Check the EUROPEAN VERSION tickbox
11 - Click ADD and select the two following items:
A1 CD-ROM
A2 CD-ROM
12 - Click F10 Exec button
The software will now ask for both CD-ROMs and copy data onto your hard
disk (about 12Mb per disk).
The temporary directory you used to copy the files into in step 1 can be
removed.
I'm stuck after 12... help please.
I think I'm on 10 though hahha...
This post has been edited by 99GT: Apr 13, 2007 - 2:25 AM
post Apr 13, 2007 - 8:09 AM
azian_advanced
Joined Apr 18, '05
From Calgary
what i did instead was i copied the contents of the data in the CD-ROM to the root directory of the hard drive.
then in the European screen, select A1 & A2 CD-ROM then select Hard Disk and click OK.
press the F10 button to accept the changes.
also if you want the JDM contents do the same in the Japanese box and select A1, A2, B1, B2 as Hard Disk also, and check mark the Japanese area box. then F10 to save.
once you have that all working, here's a quick how-to on how to use the program:
To view a part (for example, GT-FOUR spoiler blocks)
1. Go to “1. Part Number Translation” from the main screen.
2. Under Model Name/ Catalog Code, click on Search and double-click on a car (“Celica ST20#")
3. Under Model, click Search and double-click the model you want ("GT4")
4. Press F10
5. In this window, you can either search by part number or just enter a keyword ("spoiler") and press F10 to enter.
6. Chose the part ("poiler Sub-ASSY, Rear") and press F10
7. You should now see an image, there may be other images as well for different options or types of spoilers for GT4. Press F8 to move forward and F7 to go backward through the diagrams. Also, by right-clicking on the image, you can zoom into the diagram for a better picture.
8. Click on the part number and press F10
To switch between, European and Japanese
1. Go to “8. Initial Setup” from the main screen
2. Choose European or Japanese and press F10 to accept. Then F4 to go back to the main screen.
This post has been edited by azian_advanced: Apr 13, 2007 - 8:18 AM
Lo-Fi Version Time is now: November 24th, 2024 - 8:36 PM
