APEX'i N1 Metal Universal Muffler, Which one would fit? |
Apr 14, 2007 - 4:38 AM |
Enthusiast Joined Nov 22, '06 From Maui, HAWAII Currently Offline Reputation: 0 (0%) |
I need to replace my stock muffler on my 6gc because I discover a hole . I seen the one I want to get APEX'i N1 Metal Universal MufflerAPEX'i USA. My engine is a 5S-FE. What is the stock exhaust piping diameter? Is it 60mm or 75 mm?
This post has been edited by MauiBuilt: Apr 14, 2007 - 2:36 PM |
Apr 14, 2007 - 7:10 PM |
Enthusiast Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
On a 5S-FE I wouldn't go any larger than 2 1/4" exhaust. As a comparison, my 3S-GTE runs a 3" exhaust all the way through.
So I would recommend you the 60mm exhaust. Also be wary that you will need earplugs for the N1 exhaust it's loud. This post has been edited by tangcla: Apr 14, 2007 - 7:10 PM -------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
Apr 14, 2007 - 9:58 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
I think the factory exhaust pipe size was 2", so ideally 2 1/4" and 2.5" should be fine. As far as the Apexi N1 muffler goes, it will be loud unless you install a resonator muffler between the cat. converter and the rear muffler. It will help deaden the sound on a custom catback setup. My exhaust setup is 2.5" pipe size with magnaflow high-flow cat. converter, resonator muffler, and Megan Racing N1 muffler. So the tone of my car should sound close to what yours will sound if you got a custom setup with the Apexi muffler.
Lo-Fi Version | Time is now: December 3rd, 2024 - 11:52 PM |
