> Power Steering Pump, When car revs ...It shots up
post Apr 15, 2007 - 12:06 PM
Gmoney1
Joined Feb 9, '07
From St.lucia
hey guys i hate to feel like i am sendig out ridiculous post but i am really need at this engine stuff and ..... an i jus rebuilt my 3SGTE ...., now i am being faced with a issuse of power steering fuild being pushed up from the power steering canister .... has anyone ever had that problem ... i kno there are 2 vaccum lines on the power steering pump ...how would i go ahead solving this problem
post Apr 15, 2007 - 8:21 PM
Remy
Joined Jan 25, '06
From MN
uh...when you mean canister you mean the resolver right ? And if the fluid is being pushed up that means you need more power steering fluid toyota recommends ATF for PS fluid. If its foaming that means theirs a leak somewhere in your PS system.
"To Protect And To Serve The Wealthy" -POLICE
post Apr 16, 2007 - 7:07 AM
Gmoney1
Joined Feb 9, '07
From St.lucia
yeah well it is foaming .. and being pushed out the resolver..........Where is the PS system located ?
post Apr 16, 2007 - 10:24 PM
Remy
Joined Jan 25, '06
From MN
I don't have pics no DC kindasad.gif but heres something that might help you. BTW taking out the PS pump is a PITA !! I just finish replacing and putting mines together. I had the same problem as you replaced my pump and now its fine no foam or noises. Oh forgot XD one case is that it foams out if you don't bleed the system. wink.gif
http://www.celicatech.com/forums/showthread.php?t=19104
post Apr 20, 2007 - 11:22 AM
Gmoney1
Joined Feb 9, '07
From St.lucia
thanx remy .. but let ask u .... there are vaccum lines that go on the back of the power steering pump ...... is there any special order as to how the vaccum lines should go ?
post Apr 20, 2007 - 6:26 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(Gmoney1 @ Apr 20, 2007 - 11:22 AM) [snapback]548822[/snapback]
No theirs no order they have to go in make sure they're not bent,twisted or criss cross and just reconnect them. wink.gif
post Apr 23, 2007 - 9:32 PM
alltracman78
Joined Aug 9, '06
From Ma
Hold on.
If pwr steering fluid is being shot out of the reservoir, there is probably too much fluid, NOT too little....
Foam is NOT always a leak.
It can and will foam sometimes when everything is normal.
Especially if you turn the wheel all the way.
Bleeding the pump is simply turning the wheel from side to side several times.
The vacuum lines are to raise the idle when you turn the wheel.
Order doesn't matter, but if there is a leak it will effect how your car runs.
Lo-Fi Version Time is now: November 28th, 2024 - 11:54 PM
