power numbers? |
power numbers? |
Apr 15, 2007 - 5:01 PM |
Enthusiast Joined Mar 20, '07 From Bradenton,FL Currently Offline Reputation: 4 (100%) |
what kind of numbers can you get out of 3sge?
Apr 15, 2007 - 6:00 PM |
Enthusiast Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
heres the info from the sitckies right above your post:
3S-GE - This engine is another engine that comes standard in many Celicas, including the sixth generation Celica ST202 and ST203(Which, sadly, aren't available in the US.) It's the same 2.0 liter block as the 3S-GTE, but rather than being turbocharged, this engine is naturally aspirated, resulting in less power and less torque. This engine is an option for people who have a Celica and want to do a swap, but they don't want or are not allowed to have a turbocharged car. Even without the turbocharger, this engine is still powerful though. It puts out 177 horsepower and 142 lbs. ft. of torque in the earlier models, and the later models have BEAMS VVT-i(Identified by red valve covers and intake manifolds), resulting in 197 horsepower and 152 lb. ft. of torque. Some people may think that they can swap this engine into their car and later turbocharge it, but this is not a great idea. The internal components on this engine and the 3S-GTE are drastically different, so to make this engine turbo-ready, it would require the use of internal engine parts to strengthen the engine. If you want a turbocharged engine, it'd be much, much easier and cost-effective to simply drop in a 3S-GTE in the first place. This engine will bolt up to any transmission that comes on a ST202, ST203, ST204, or ST205 with no problems, though the stock tranny may not be up to the task of handling high horsepower levels if you have a USDM GT(ST204) for example. user posted image |
Apr 15, 2007 - 8:32 PM |
Enthusiast Joined Sep 23, '02 From local petrol station!, UK Currently Offline Reputation: 0 (0%) |
QUOTE(purepunishment @ Apr 15, 2007 - 11:01 PM) [snapback]546979[/snapback] what kind of numbers can you get out of 3sge? For a non-beams 3sge, your gonna be hard pushed to get more than 190-200 hp without spending loads of money! -------------------- 1996 UK white ST205
1998 UK silver ST202 Nothing is fool-proof to a sufficiently talented fool!!! |
Lo-Fi Version | Time is now: November 26th, 2024 - 10:40 AM |
