2 Pages V  < 1 2
> Toyota Gasoline?, Preference
post Apr 20, 2007 - 4:28 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
lol additives are not gimmicks at all, but buy the cheapest non branded grocery store gas you can get and then after a couple years have your injectors flow tested and take a look at your piston tops.
post Apr 20, 2007 - 4:33 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Bitter @ Apr 20, 2007 - 9:28 PM) [snapback]548904[/snapback]
Maybe if you guys made an argument about "WHAT" additives do and "HOW" they can affect performance... then the discussion can go on. So far... it's like trying to convince Christians that God in fact did NOT create humans (*GASP*). People can believe whatever they want... but at least have a good reason. "Dirty engines" as you're trying to argue here is almost always caused by the PCV system... you know... excess oil and pressure bleeds off into the intake... which combines with the air/fuel mixture and gets burned. Yeah...
This post has been edited by Kwanza26: Apr 20, 2007 - 4:34 PM
post Apr 20, 2007 - 4:38 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
"Will you take the Red pill?.....or the Blue pill?"
"Which one is the placebo?"
"The red pill."
"Fork it over."
"/sigh"
post Apr 20, 2007 - 5:26 PM
dagreat1
Joined Mar 27, '06
From Gainesville
so which octain should we be using?
post Apr 20, 2007 - 6:52 PM
Insanity-74
Joined Jan 9, '05
From Under the car
Petrol octane ratings and additives, This is is a hugely complicated subject.....Octain rating...this is the petrols ability to resist pre detonation, where the heat of the engine components ignites the petrol before the spark plug does. This can decrease the power of a car because if the petrol ignites before the piston reaches the top of its compression stroke, then the engine is fighting against the detonation of the petrol/increased pressures = reduced power, broken pistons etc etc, So Octain rating can/does improve power.
Petrol companies use different methods to produce the "Octaine rating" in petrol.....Shell does this in there V-Power by making a higher grade of fuel, ie there 99ron petrol is produced as 99ron petrol.
Companies like Greenergie which also makes a 99ron petrol use a different method, they get fuel from either themselves at 95ron or buy it from any other compay at 95ron and add aditives to increase the ron rating synthetically.
Obviously the Shell petrol should be better being origionally designed as a 99ron fuel, but most companies add detergents etc to the fuel to help clean the engine etc...this does nothing to improve power, but can improve overall performance by maintaining the engines internal workiing parts, keeping them cleaner etc.
If you look in Evo mag from late last year they did a fuel comparison.
BP`s 98ron Ultimate came top in both HP gains and torque gains over regular 95 ron petrol. Greenergies 99ron came second and Shells 98 ron came third so I guess its whatever petrol suits your car....Petrol isnt just petrol though there are many differences caused by production techniques, types and percentage of addatives ron ratings etc etc
Now we get 99ron shell and 102 ron BP ultimate plus both of which give a noticable increase in performance over regular 95 ron petrol.
Normal engines (non turbo) do not produce much heat so dont need the pre det resistant properties of high Octain fuel, so you wont need to run anything beyond 95ron...turbo cars should run 98 ron or higher unless mapped to run on the lower grades of petrol.
Note - Petrol in the states is produced usually at a higher grade than elsewhere, also the grade is rated in a different way...RON......PON etc
post Apr 20, 2007 - 8:28 PM
Steevo
Joined Jul 19, '06
From Colorado
http://en.wikipedia.org/wiki/Octane_rating
The detergents are more for the FUEL system than for the intake system. And the fuel is not fully evaporated or intermixed by the time it reaches the back side of the intake valve, partially allowing a 'wash' of the valve. As a fact you can check with engine manufacturers and the direction of swirl on test engine scan be determined by what side of the bore is worn more, the un evaporated fuel hits the side and washes the oil off partially causing slightly accelerated wear.
But to be honest, unless you NEED the extra octane, it is a waste to use higher octane fuel.
But it does seem to me as well that shell has a better formulation than other brands, based on personal experiance, and many trips to see my parents 1,600 miles away. Both in fuel mileage and in performance "feel".
This post has been edited by Steevo: Apr 20, 2007 - 8:42 PM
post Apr 20, 2007 - 8:42 PM
DSToyo
Joined Dec 16, '06
From Maryland
hows wawa gas stand on the list?
x2 on shell is best.
post Apr 24, 2007 - 12:05 PM
Jeremiah
Joined Mar 19, '06
From Rocklin, CA
Anyone have any real evidence, or is this all just opinions and conjecture? If shell / chevron fuel is REALLY that much better, how come evidence of it is so weak?
And, Kwanza26 is correct about the octane thing. Unless you have an engine that REQUIRES more pre-detonation resistant fuel (over-sensitive knock sensors, high compression, forced induction etc), it won't make you go any faster.
post Apr 25, 2007 - 6:44 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
True, it's not going to make you go any faster. My only complaint is the cleanliness of said companies, so I prefer Shell due to the perceived quality of the gasoline over others.
Took a tip when my lawn mower starting dying regularly and when serviced they asked what kind of gas I was using. Turns out multiple people were having theirs serviced as well due to Arco gas being used. Switched to Shell and never had a problem with it again.
QUOTE(DSToyo @ Apr 20, 2007 - 8:42 PM) [snapback]548971[/snapback]
Oh and uhh, Air Five all the way from Washington! Shell kicks ass!
This post has been edited by GTS13: Apr 25, 2007 - 6:43 PM
post Apr 26, 2007 - 12:34 AM
NuSpec02
Joined Aug 13, '06
From Lilburn, GA
I filled up with gas from QT and my check engine light came on lol.
NEVER AGAIN.
I thought it was the additives adjusting cuz it went off after a while.
And in my opinion, different companies do affect the car diffferently..
My brother put walmart gas in my car (i ought to kill him) and my car had a rough idle until i ran out of gas and filled upwith another company. And when i did fill up with was with shell....I noticed a power difference with acceleration and when i'm at 4000 RPM and the 2nd came kicks in.
I notice the difference and i do believe discounted and cheap gas don't have a short term effect (such as filling up once and MAYBE twice). If you use it all the time, i reccommend fuel injector cleaner and etc. etc. Because it does affect your car.
I use shell all the time. If not its chevron, and sometimes BP.
now.. tell me this.. doesn't any one here LOVE the feel of fresh gas in your car?!? I love it! The acceleration is amazing redface.gif).
This post has been edited by NuSpec02: Apr 26, 2007 - 12:36 AM
"Guard Your Honor, Let Your Reputation Fall Where It Will..."
1998 Toyota Celica GT - Nu Expectation.
post Apr 26, 2007 - 3:18 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Yeah I noticed the same thing with my Camry. I let my friends mom borrow it and she had filled it up after using it. When I drove it I noticed that it just didn't feel the same, until I filled it up again with Shell and it accelerated my better. Not to talk up Shell but more so talk down about the gas she put in.
post Apr 26, 2007 - 3:29 PM
Negative
Joined Apr 28, '04
From Houston, Texas
rolleyes.gif All these people with the same experiences yet people will still get on here and laugh because they think we are falling for "gimmicks". WTF ever.
post Apr 26, 2007 - 3:40 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
*sigh*
People let this sh!t die unless you have something productive to add. Gas is gas (minus octane ratings of course)... additives is what makes the gas different... but do they affect performance? NO! The additives are specifically designed to maintain the fuel system, ie: less fuel filter clogs, etc... but that does NOT affect how the engine burns the gas. Shell is NOT a miracle fuel that makes a car significantly better. That's just ignorant. GAS is GAS. If your car has trouble from pumping some cheap indy fuel... well... it's either placebo or your car has problems.
Something you all might want to know... indy gas stations across the united states buy whatever is cheapest. One week they might have Shell, one week exxon, one week BP. The tankers all get their fuels from the same refineries, it's just after they buy it, they put in their own stuff.
In the end... if you wanna fork over more cash to keep the rich pigs happy... be my guest. Just don't preach cluelessness.
post Apr 26, 2007 - 3:47 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Negative @ Apr 26, 2007 - 8:29 PM) [snapback]551099[/snapback]
Do you really think people here are an accurate sample of the general population? People here are enthusiasts who are willing to spend for performance. If that alone doesn't tell you something... then sorry you just don't get the fact that you've been bought by a gimmick. Kinda like Starbucks coffee is magically better so it's OK to spend twice as much... yet Consumer Reports's blind taste tests show consumers picking McDonalds' "cheap" coffee over Starbucks. Heheh... yeah. In the end... it's your money... do as you will. If these other "cheap fuels" were that bad... why/how are they even still competing?
post Apr 27, 2007 - 5:54 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
QUOTE(Kwanza26 @ Apr 26, 2007 - 3:40 PM) [snapback]551106[/snapback]
*sigh*
I find it hilarious that you get so upset over it. While their may be no difference in the fuels, you sir are still defending what you prefer to use just as the rest of us do. Your preference just happens to be the cheapest; so while we preach ours your just as guilty for preaching yours.
post Apr 27, 2007 - 6:20 PM
gas is gas. the only thing i would worry about with cheap shady looking stations is that they might have 87 in their tanks but lable it as 93 to try to make a profit. but that wouldnt matter much for most na celica owners. the car was factory tuned and designed to run on 87 octane.
post Apr 27, 2007 - 7:30 PM
Hanyo
Joined Aug 16, '03
From Bay area
I admit it. I'm a fuel sucker.
I've dont mpg test on my own and deterimined that shell gas give more MPG then arco... ect.
This and I have a shell card, so i get a slight discount on gas.
However, i do not believe the advertising strategy of gasoline cleaning my fuel system.
post Apr 27, 2007 - 8:03 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Esso
Their points are exchangeable with visa points so I can rack em up faster smile.gif That's my only reason (and it's on the way home from work)
87 octane here. Gas prices are high enough, I don't need to pay more for my daily commute to work. You won't find me drag racing around town anytime soon.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 7:19 AM
